Just For Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 11:42 PM   #1
Just For Copper
Hi,
I was at a local hardware store today I was browsing as I waited for my wife.In the plumbing section I saw a product called Just For Copper.The label says it is like a liquid solder that provides a cold weld to bond copper pipe to a copper fitting.It can be used in tight spots and where it isn't safe to use a torch .It is made by a company called Jaco..The 5 ounce bottle says it will do 40 welds,for $12.99.It is tested and guaranteed as long as you follow the directions.Has anyone had any experience with this product.Also a friend of mine would like to know if the Sharkbite fittings are as good as they advertise?
Thanks For Your Time
Don
JUAN1955 is offline   Reply With Quote
Old 02-25-2012, 11:54 PM   #2
Rewards Points: 12,882
I'd forget the magic goop and use Shark Bites instead. And yes they really work.
JUAN1955 (02-26-2012)
