Just Can't Break Sink Drain Free! - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2008, 03:04 AM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Just can't break sink drain free!
I've been at this for a couple of days now. The mom & pop store finally got 2 of the faucets in that I was waiting for that had long enough necks to reach the 70's sinks without pouring out on the coutertop. After I got one faucet installed and sealed one valve leaked, and there was no way to replace it. (Don't buy Oak Brooke!)
And I still can't break the drain free; I managed to break the whole marble countertop away from the wall and cabinet, but the drain won't budge
. It rotates in the bowl, but I can't break the nut or escutcheon loose and the pipe doesn't move. I've soaked it with penetrating oil each time in hopes that the magic will loosen this junk so I can have a working drain plug.
Do I just need to wait for the new sink and cabinet?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 03-03-2008, 04:22 AM   #2
Oldguy
Rehabber's Avatar
Cut the nut with a sawzall (carefully)
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 03-03-2008, 02:02 PM   #3
Fixer-'til-broker
Rewards Points: 262
Thought about it after banging it with the pipe wrench - not too much room to maneuver. Maybe a Dremel wheel or angle grinder...?
Old 03-03-2008, 02:42 PM   #4
Is it possible for you to take a bare hacksaw blade and insert it down into the drain to where you can begin to cut through the ring at various points so as to relieve some pressure on the threads? Don't go all the way through the drain pipe it's threaded onto. Then, you might be able to pry a piece of it up for a grip and take a pair of vise grips and simply twist the drain ring out and off.
End Grain is offline   Reply With Quote
Old 03-03-2008, 05:09 PM   #5
use a drill bit and drill thru the nut. Do this in two different spots then seperate the nut.
redline is offline   Reply With Quote
Old 03-04-2008, 10:07 AM   #6
Learning by Doing
Leah Frances's Avatar
If you decide to cut the nut with a power tool wear protective gear (face shield, long sleeves/pants, gloves)! I had to dremel some bolts off a sink this fall. More than one cutting wheels failed and shattered shooting burning hot shrapnel around the room.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-05-2008, 10:56 AM   #7
Fixer-'til-broker
Rewards Points: 262
Got it - thanks!
Leah - I hate using Dremel cutoff wheels, exactly for the shrapnel reason. I got by using the old one that was on the bit up until the last cut. Then the replacement shattered on contact. The next lasted a bit longer. That dust made such a mess in the porcelain sink! I haven't found much use for the Dremel besides grinding the dogs' toenails, but it managed to cut through the grommet nut and the drain face (forgot what that part was called).
This must've been the original drain pipe - the bottom fell apart in my hand when I removed the P-drain. All kinds of nasty funk in there! No treasure, though.
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 09:36 AM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
