Just Bought A Foreclosed Home,All Copper Stolen, Should I Replace Or Use PEX Or PVC? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-16-2010, 08:35 PM   #16
Rewards Points: 150
Like any other quality popular tool, you can buy it and should have no trouble recouping 70% of your investment selling it on ebay.
johnnyboy is offline   Reply With Quote
Old 02-16-2010, 11:01 PM   #17
Not totally sure about codes, but based on my experience as a DIYer for an irrigation system, the industry consideres PVC to be inappropriate for indoor use. It's only considered reliable enough if it's burried (so it's primary application is in irrigation).
If it was me redoing all the plumbing in a home, I'd go with the PEX just because it seems like it would install faster. I've done the copper sweating and the PVC gluing, and it takes a lot of time doing all those joints, and getting pipe lengths just right. PEX on the other hand being bendable doesn't seem like things have to be so precise and you have fewer connections to make.
HooKooDooKu is offline   Reply With Quote
Old 02-16-2010, 11:10 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
easy with words like doesnt have to be so precise,some of us are contractors here!
plummen is offline   Reply With Quote
Old 02-17-2010, 12:17 AM   #19
I just ment that because PEX is so flexable, the run of the pipe doesn't have to be cut to just the right lengths as you try to locate the pipe quite as precisly as when working with hard pipe.
As an example, think of making a 90 degree turn to go up through a floor. With hard pipe, you've got to get the pipe just before the 90 degree elbow the right length so that after the elbow the next pipe will properly point toward the hole. But with PEX, you just push the pipe through the hole and pull it up as needed to make the corner.
I know that when I've been working with copper and PVC pipe, the thing I've hated the most is when I would have to do what I would call "precision plumbing". This would be when the exact location of where you're going with the pipe is already set and therefore you've got to get pipe lengths and angles just right to hit your target. By contrast, if you're doing irrigation work and you've got a 4 inch wide trench to work with, it doesn't matter as much when a pipe gets cut a 1/2" shorter going around a corner than you intended since you don't have to be dead center in the trench.
Old 02-17-2010, 11:24 PM   #20
Rewards Points: 79
Do i use 3/8" for everything? or 1/2?
ehoez is offline   Reply With Quote
Old 02-18-2010, 07:12 AM   #21
the Musigician
DangerMouse's Avatar
Originally Posted by Snav View Post
What's this "special tool for pex" that everyone talks about? :D
I've never used one - I have a basic pipe-cutter and I use sharkbites, I use screw-in U brackets to hold my pipes in place, voila.
yeah, but a handful of sharkbites costs as much as the tool and pieces....
the tool can be resold on CL....
great way to go though if you can afford them!
so rats like to chew this stuff? that could be a problem here in the boonies, the dogs and cats catch the occasional rat and shrew as well as mice.
DM
Old 02-18-2010, 07:50 AM   #22
Military Mom of 4
Snav's Avatar
Oh - it's an expander!
I had to go and read up on it to see what it does - if I need a new toy in my toybox surely I should know about it!
I got ya, now - I was confused and wondering if I was doing something wrong
Yes, you're right - the sharks for one bathroom equal the cost of the expander.
At least expanders can be resold and thus recouping some of the cost.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 07-10-2011, 04:32 PM   #23
Rewards Points: 79
thanks everyone
Old 07-15-2011, 02:03 PM   #24
We are in the same boat as you are, closed on a foreclosed house my husband has just arrived , but whoever was foreclosed upon decided to destroy all the pvc pipes in the basement. Husband is researching the pex ave today. We are planning on living in the house. Interesting thread. THANKS
Datura is offline   Reply With Quote
Old 07-15-2011, 02:12 PM   #25
the Musigician
CPVC is still probably going to be much easier. How much of the pipe did they 'destroy'?
Also, it'd probably be much cheaper to just repair the damages. Did they rip the sink/tub fittings apart?
Did they destroy the drains? Can you post pictures?
DM
Old 07-15-2011, 07:45 PM   #26
Thread killer
Rewards Points: 272
Originally Posted by ehoez View Post
i found PEX prices @ for the blue
$30 for 100' and $90 for 300'
is the red higher priced? and what does oxygen and without oxygen mean?
The red shouldn't be priced higher. The with/without oxygen is probably specifying whether you can use the pipe in a heating system. Closed loop systems need an oxygen barrier to prevent rusting
Canucker is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Installing copper gutter to replace some concrete tiles whattodo Roofing/Siding 2 07-28-2009 07:28 AM
PEX or copper to replace old pipe indoors? Ultrarunner2017 Plumbing 15 03-29-2009 10:44 AM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-10-2008 10:47 PM
