Jucuzzi Tub Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2013, 05:48 PM   #1
Jucuzzi tub issue
Question,
I had my bathroom redone two years ago, along with a jacuzzi tub with an in-line heater. I have to also tell you I have a 40 gal. Hot water tank as well. The jacuzzi is called Katheryn, made by Kohler. I totally forgot about the water issue and the jacuzzi. Its been two tears and no baths can be taken due to hot water filling up the jacuzzi quarter ways before going cold.
I have been thinking about putting in a tankless hot water tank. Is this a good idea? Do I put in a larger 50 gal tank? Mind you space is very limited. Please help.
Keith vent is offline   Reply With Quote
Old 02-18-2013, 05:56 PM   #2
Rewards Points: 13,752
That would work if you do not mind spending a few thousand on buying one and up grading the supplys.
Old 02-18-2013, 06:49 PM   #3
So, that did not answer my question. What is the best idea?
A larger hot water tank?
Old 02-18-2013, 08:29 PM   #4
Rewards Points: 582
hi keith...some people have a 50gal hi recovery heater installed when they a whirlpool tub ....I installed my bath with whirlpool tub its operating gallons were 55 gal...i installed 50 gal heater just for wp tub its great...40 gal for the rest of the house...no trouble ..ben sr.......it may cost a few more dollars to run ..but the tub is a want ..and not a need ..lol
Old 02-18-2013, 09:38 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
I don't care for the tank less heaters, a larger tank quick recovery, also need to take in to account the distance from the heater to the tub, 66 to 80 gals with out running calculations,
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-18-2013, 10:35 PM   #6
So thankless heaters are more expensive and not energy efficient?
Is it better to add another hot water tank (50 gal) quick recovery and plumb the two tanks together?
Old 02-18-2013, 10:49 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you were going to put in a tankless ONLY for the bathtub, I think you would probably find that it works pretty well.
Of course you have to factor in the cost of the heater 1200 +
The cost of running a gas line (or bringing in a second 200A electrical service if you go electric)
as well as having the current lines to the tub capped off and rerouted to the new heater.
For a whole house, I don't think they are so great.
All that said, I think it's a whole lot of money just to take a bath. about 1000 bucks is what it would cost for me to install an 80 gallon water heater.
I think as a whole, it would be simpler to put in a 66 or 80 gallon water heater in place of your 40.
Also : You do realize that the heater in the jacuzzi line isn't really a heater, it's a temperature maintainer.
Journeyman Plumber
Old 02-18-2013, 10:57 PM   #8
your Idea is quite practical as you are short on area
SmithTitos is offline   Reply With Quote
Trane XR90 issue jasun HVAC 7 10-08-2012 06:18 PM
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 10:25 AM
Westinghouse furnace issue joe8918 HVAC 9 12-04-2011 05:50 PM
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 12:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 06:49 PM
