Joist Holes Sister Joist - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-08-2015, 05:48 PM   #1
Rewards Points: 16
I have improperly drilled holes in my joists. Would it be ok to sister a deeper joist with the hole drilled properly to the bad joist to correct the problem?
ragart is offline   Reply With Quote
Old 11-08-2015, 08:05 PM   #2
Trucon01's Avatar
Rewards Points: 510
Can you post a pic?
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 11-08-2015, 08:08 PM   #3
Rewards Points: 16
Here it is.
Old 11-08-2015, 08:13 PM   #4
Trucon01's Avatar
Rewards Points: 510
What size joist and what size hole did you cut?
Typically you don't cut any holes in the top or bottom 2 inches. And only a hole 1/3 the size of the joist.
Old 11-08-2015, 08:17 PM   #5
Rewards Points: 16
2x10 joist. 2.5 in holes. i didnt do it, plumber friend did. Looking for the way to get it right. Unfortunately the plumbing needs to be where it is. Was thinking of sistering a 2x12 with the hole in a safe place.
Old 11-08-2015, 08:21 PM   #6
Trucon01's Avatar
Rewards Points: 510
You could sister both sides with 2x10s. Glue and screw. Or feel free to use bolts instead of screws. Better shear strength
Old 11-08-2015, 08:28 PM   #7
Trucon01's Avatar
Rewards Points: 510
Can you also show the pvc fitting he used for this drain line? From far away it looks like a sanitary tee, which cannot be laid horizontally
Old 11-09-2015, 10:04 AM   #8
Rewards Points: 16
Thanks. From memory I think it was a wye and not a tee, but I will double check that tonight.
Old 11-09-2015, 05:21 PM   #9
Rewards Points: 1,956
I see a rubber fernco hiding up there.
Old 11-09-2015, 05:26 PM   #10
Rewards Points: 16
Yes. There is no water flow through that, it connects to the vent stack. Is that improper?
Old 11-09-2015, 05:27 PM   #11
Rewards Points: 16
Also it is a tee fitting, but I'm told through another plumber that that is ok as the line is not horizontal, but sloping.
Old 11-09-2015, 05:29 PM   #12
Rewards Points: 582
yep see a fernco and looks like he used a tee ???
Old 11-09-2015, 05:33 PM   #13
Rewards Points: 16
Only air is flowing through the fernco and the sanitary tee is connecting two sloping pipes. Is that still improper?
Old 11-09-2015, 07:05 PM   #14
Rewards Points: 2,638
Kinda hard to see from the photo, but are those joists supported 3 feet to the right and 3 feet to the left of the PVC pipe ? If those joists are only 6' between supports, I would not worry about it.
SPS-1 is offline   Reply With Quote
Old 11-09-2015, 08:10 PM   #15
Yes! All rubber fernco's are not an approved fitting for any plumbing exception is outside sewer.
A sanitary tee in the horizontal or on it's back receiving drainage is an illegal use of fittings.
If what you say is true that through the fernco is only air. You also now have a dry flat vent that is illegal under IPC.
Sistering to correct warped joist... fprawlings4 Building & Construction 2 03-12-2013 08:04 PM
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
How to Sister I Joist datahoe Building & Construction 18 12-31-2012 06:53 AM
Cracks in joist clydesdale Building & Construction 4 01-04-2011 08:08 AM
sister a joist Jack Hass Carpentry 7 06-19-2007 05:39 PM
