#1 |
Joint compound on brass fittings for natural gas?
Hi,
I recently had my bbq converted to natural gas. The gas is coming in on a black iron pipe with a shutoff valve and a 1/2 inch flare. I need to split the line using a T-connector (to run gas to main grill and a separate side burner). Should I use joint compound on my connections? Thanks in advance! |
#2 |
Use pipe dope for non-flared fitting. Flared fittings need nothing.
#3 |
I have gas!
I'd use pipe dope on all black pipe connections. Make sure you use the one that is specifically for gas.
I tear things down and build them up. |
#4 |
Flare fittings are machined and need no joint compound on them.
If you have never made a mistake, you haven't done much. |
#5 |
HVAC / Plumbing
Joint compound on brass fittings for natural gas? |
#6 |
Plumbing Contractor
Gives me the warm fuzzies too. Just remember that on compression and flared fittings the threads are NOT what causes the gas/water tight seal. On compression it is the ferrule and on the flared fitting it is the mating surfaces themselves. The use of the pipe dope on ferrules and mating surfaces doesnt hurt and well I love those warm fuzzies.
| Tags |
fittings, joint compound, natural gas ![]() |
| Display Modes | |
| spackle versus joint compound... | joeyboy | General Discussion | 11 | 02-26-2011 08:51 AM |
| defective joint compound | newbpainter | General Discussion | 8 | 05-24-2009 10:52 AM |
| Joint compound to smooth old paint layers. | gmhut | Painting | 1 | 05-03-2009 06:50 PM |
| Hairline crack in joint compound | elbee | Building & Construction | 10 | 12-02-2008 06:57 PM |
| What brand of Joint Compound? | mwehnes | Building & Construction | 6 | 03-26-2007 08:11 PM |
