Joining PVC To Existing Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2012, 08:38 PM   #1
Joining PVC to existing drain
Gutting the whole master bath down to the studs. We had two sinks in the existing bath, and will have two again with the new.
I have to replace the sink drains, and intend to use PVC. But before the drain goes into the soil pipe I need to join it to metal.
My plan is to cut the old metal pipe back close to the soil pipe leaving the fitting from there in place, brass maybe. Then I'll have a rubber hub coupling to join the new PVC to the old copper drain.
Pulling as much of the old drain as possible. It has 50 yrs of buildup and developed pinholes in places (which started the whole process)
I'm not that comfortable with a rubber hub coupling and then just drywalling this back up. Is there a better method than this?
Live in Pennsylvania.
Thank You
Startinover is offline   Reply With Quote
Old 02-14-2012, 09:19 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
Remove the threaded male in the black pipe then convert to your new material. Stay away from those rubber coupling.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-14-2012, 09:25 PM   #3
Rewards Points: 636
been using shielded fernco's for years and have seen them in service for years next best option would be remove all old run all the way in plastic
jaydevries is offline   Reply With Quote
Old 02-14-2012, 09:35 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
How about a picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 10:42 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 904
Not sure I'm following, but it seems like the weakest point of your idea is leaving the copper stub at the cast iron stack. Remove it and use a "Tyseal" doughnut in the hub to connect the new PVC line.
As for the rubber couplings, as jaydevries said, the shielded ones are the way to go. In fact, my inspectors don't allow the normal unshielded ferncos inside the building.
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-15-2012), plummen (02-15-2012)
Old 02-15-2012, 08:51 PM   #6
Rewards Points: 582
fernco cupplings are ok and hold up well..but I would remove pipe from stack and install male adapter then glue up your pvc this is the best method...ben
Old 02-15-2012, 09:17 PM   #7
Rewards Points: 636
i agree with eplumber a tyseal is the best i like them 100 times better then the fernco brand donuts just harder to find
Old 02-19-2012, 06:39 AM   #8
Thanks for all your advice. I will post some pics of this, but it will be a little while before I pull off the ceiling below again.
Old 05-20-2012, 06:50 AM   #9
Update with pictures
As you might imagine, I've had other emergencies, and we have other bathrooms. As I should have from the beginning, I attached some pictures.
The drain from the sink looks like it threads into the soil pipe. The drain from the shower has a fitting that threads in. I think I should start from the soil pipe new, but whats the chance of being able to thread a new fitting into a 50yr old soil pipe?
Joining PVC to existing drain-overview.jpg   Joining PVC to existing drain-sink-soil.jpg   Joining PVC to existing drain-sink-soil-2.jpg   Joining PVC to existing drain-both-joints.jpg   Joining PVC to existing drain-shower-drain-overview.jpg
Old 05-20-2012, 08:32 PM   #10
Plumber
Rewards Points: 904
You've got your hands full if you want to change that pipe.
It's actually copper. Cut it and try to unthread it. Use a big wrench with a cheater bar. Good luck. What are the O.D. measurements of those pipes?
Old 05-20-2012, 08:38 PM   #11
Rewards Points: 582
those copper pipes should unscrew ..may need alittle heat...as i said use 1 1/2 pve male adapter screw into cast glue pvc into adapter...
Old 05-20-2012, 09:00 PM   #12
Rewards Points: 636
well the one copper pipe looks like it is threaded in and the other copper pipe"looks like a brass 90" is leaded in. if not willing to replace cast at same time"which would be best option" i would use shielded copper to pvc fernco.
i to this day do not understand why some plumbers think they are like the black plague thay care all the correct certifications to be code legal. also i want to know if you do not use them how do you do a high end residential job or some commercial jobs where no hub cast is spec. due to sound and or fire reasons. unless you just do not bid on them.
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
Old 05-20-2012, 09:30 PM   #13
plummen's Avatar
Thyeres a differance between a plain old rubber fernco fitting with a hose clamp on each end and a no-hub or mission coupling which has a stainless shield and gets secured with 2 to 4 clamps depending on the style you buy.
The only place Im allowed to use a plain old rubber fernco with the 2 clamps around here is outside the foundation/perimiter of house or building on a sewer.
The Following User Says Thank You to plummen For This Useful Post:
jaydevries (05-20-2012)
Old 05-20-2012, 09:31 PM   #14
Plumber
Rewards Points: 904
I can't tell the pipe sizes- hope its not 1.25" which can be found in my area. That would pose a problem.
As for shielded couplings, It's all I use inside a building. Like you said, sound proofing stacks using CI or air plenums and fire walls that dictate noncombustible materials.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 05-20-2012, 09:37 PM   #15
plummen's Avatar
2nd picture should be a fernco 3x4 increaser and 1st picture should be a no hub coupling.
Fernco fittings with 2 clamps are for outdoor use,the shieloded no hub couplings are what we're required to use on work inside foundation including ground work for non gluable joints
TheEplumber (05-20-2012)
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 02:28 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 01:48 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
