Joining Pipe Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2011, 09:40 AM   #1
joining pipe fittings
how do i join galvanzied pipe fitting to a galvanized pipe fitting? and how do i join galvanized pipe fitting (thread) to pvc backflow preventer (female)?
boxhead is offline   Reply With Quote
Old 07-01-2011, 09:59 AM   #2
Rewards Points: 1,578
Depends on what the ends of each pipe are. Typically, these thread together using a coupling or a union, elbow, or tee.
a transition fitting
Pictures of the pipes, the backflow device with sizes would help.
bob22 is offline   Reply With Quote
Old 07-02-2011, 11:16 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You have a pvc backflow preventer??
You don't want to thread a metal fitting into a plastic female fitting. So if you have 2 fitting ends and 1 of them is plastic, your best bet is to use a schedule 80 nipple.
Journeyman Plumber
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
pipe fittings johnfin Plumbing 4 03-26-2010 09:56 AM
iron pipe fittings Talman48 Plumbing 2 01-10-2007 05:11 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
