Joining Galvanized Pipe To PVC - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2011, 03:28 PM   #1
Joining galvanized pipe to PVC
I would like to re-route an underground waterline to a bathroom in an out building in the backyard. The existing waterline is galvanized pipe and leaks. I would like to use PVC for the re-route. My question is how to connect the galvanized to the PVC. Some have suggested using a compression joint, others say PEX.
jtitus is offline   Reply With Quote
Old 12-31-2011, 05:40 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Ayuh,... With a threaded adapter...
The Following User Says Thank You to Bondo For This Useful Post:
plummen (12-31-2011)
Old 12-31-2011, 05:43 PM   #3
Rewards Points: 582
replace all the galvanized pipe.....thats the right way..use copper or plastic..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 12-31-2011, 06:14 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 924
join to the galv. using a male IP PVC adpt.
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 12-31-2011, 06:48 PM   #5
Rewards Points: 14,312
The key words in your post is "it's leaking" remove all of it and go with Pex or PVC.
Old 12-31-2011, 07:04 PM   #6
Plumber
Rewards Points: 924
But the OP's question is how to connect galv. to PVC
Old 12-31-2011, 07:16 PM   #7
Rewards Points: 582
I think me and joe are looking at this from another angle...if his galvanized pipe is leaking now..why connect on to it only to start leaking again....should have been replaced long ago....but thanks for keeping us on track..e plumber..yes they make male and female adapters.... they will work in his case....
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 12:10 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
Help needed 3/4 poly pipe joining sections. TomClarkInLubbock Landscaping & Lawn Care 3 08-13-2007 06:44 AM
