Old 12-01-2006, 05:52 AM   #1
Joining cpvc to copper?
I am installing a new water heater for my parents and have a question about joining cpvc pipe to the old copper lines. I am using Flowguard Gold pipe and purchased two shark bite couplings for joining the two together. Has anyone had any problems using this type of coupler? A good friend works for a plumbing supply house and said this is what all the plumbers are using. Just wanted to hear some feedback about them. Thanks for any help you can give.
Randy
randalg is offline   Reply With Quote
Old 12-01-2006, 07:43 AM   #2
I have not used this type connector but I have included a link to a site showing how the fittings work. At the bottom of the page you will see advice to check with Local Code office for usage guidelines. I noticed the many "claims" as to how these fittings can be used but also know they would not be allowed in all Regions due to Code.
http://cashacme.com/pdf_sharkbite/sa...Sales61305.pdf
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-01-2006, 08:51 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Here there code approved, I don't use them myself, but they are new, test of time is the factor here.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-01-2006, 09:21 AM   #4
I agree with Ron. Maybe I am just too old to change my way of doing things, but then again, I remember the Poly Folly (which was Code compliant) so I just stick with what has been proven over the years.
Old 12-01-2006, 12:32 PM   #5
Thanks for the response! I guess I'll try them and see how they work. Thanks again!
Randy
Old 12-03-2006, 08:42 AM   #6
Well, the sharkbite couplers do install very easy! No leaks yet. I guess only time will tell if they are what they claim to be. I'll post later if any problems do develop. Thanks!
Randy
More On This Topic
Hey it's Don Golden again for Expert Village and we are going to talk about copper pipes today, how to work with them, how to cut them, how to sweat them and what I want to show you now is a very important aspect of getting these things together and... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
If you like putting things together with your hands, a career as a plumber might be for you. Plumbing is a highly skilled profession and one that will always be in demand. Plumbers install, maintain and repair the systems that keep our water flowing... Read More »
How to Use Copper Pipe
How to Use Copper Pipe by Expert Village
Hey again, Don Golden for Expert Village. We just had a lot of fun working with this copper pipe and I showed you how to put it together, how to clean it and what you want to use it for. Now again, this application really was just for demonstration. This... Read More »
Now, there is an aesthetic issue that I want to take care of before I start making all my cuts and preparing all my notes to place on the xylophone bar. And that is, when you buy a copper pipe from the hardware store it's going to have red lettering on... Read More »
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
Copper - CPVC - PEX AlbrightPM Plumbing 28 01-25-2007 07:43 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 09:11 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
Copper re-pipe laxjtf Plumbing 4 02-12-2005 02:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
