Jets On Tub Do Not Work - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2011, 10:21 PM   #1
jets on tub do not work
I have a Novi tub with jets. The jets have not worked since we moved into the house. There are no loose wires, and the outlet has power. The on/off button is stuck in a pushed down position. It has been pried up once but when pushed down stayed down. We are just wondering what options could be considered to make this tub work or make sure it will not ever work. If possible, we would like to not have to hire a plumber
wbluvsrb is offline   Reply With Quote
Old 08-19-2011, 10:34 PM   #2
Dumb question but is there an extra switch on the wall or in the next room, also are you sure your getting power to it. I had 1 house they had a switch on the wall by the mirror for the jets, in the other bathroom it was plugged into a GFI that was tripped.
Adam_M is offline   Reply With Quote
Old 08-20-2011, 03:59 PM   #3
Rewards Points: 93
Probably don't need a plumber BUT you may need an electrician.
George6488 is offline   Reply With Quote
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
