Jet Pump Won't Make Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2010, 08:46 AM   #1
Jet pump won't make pressure
After spending over $400 I'm going to try this on my own....with your help.
Background.....My foot valve let go and the guy that replaced it started messing with the pump also.It's a Jacuzzi 1/2 HP I think.Before the foot valve let go I ran it at 50lbs shut off 35lbs turn on.When he got done messing with it(and another of his fellow workmates on another call) I was down to 32lbs shut off.That gradually got worse to the point that last night I had to adjust the pressure switch again cause it wouldn't shut off,down to 20lbs.
I need to know where is the best place to start tackling this from.As of this moment I have the tank drained(it had very little water in it,no bladder) The venturi tube out(looks fine) and the fitting unhooked from the pump to the tank.The fitting that goes from the pump to the tank was loose with a slight leakage.Could this be the cause? Thanks in advance for your help.
Pat
buick60 is offline   Reply With Quote
Old 10-13-2010, 12:52 PM   #2
Pat
All it takes is a little flake of rust to cause this. Or, a pinhole in the drop pipe.
Pull it out and see what is going on.
Mr. Green is offline   Reply With Quote
Old 10-13-2010, 02:16 PM   #3
As soon as he replaced the foot valve he cleaned the pump....no rust.I have a lot of Iron in my water,but that isn't the issue I don't think.A pin hole....it would have to be from the well to the pump.No sign from the well unless it was done inside the well when he did the foot valve.....
Old 10-13-2010, 04:19 PM   #4
So I took every connection off the pump and tank and re did them all with tape....put it all back together and got up to 23lbs.......
Old 10-13-2010, 07:01 PM   #5
It likely IS in the well.
Old 10-13-2010, 07:08 PM   #6
Great,now I have to pump out the well and I may as well change the down pipe that the foot valve is on.Maybe I'll luck out and it will be at the top elbow (which is still under water) and I can tighten everything up there.
Old 10-14-2010, 06:31 AM   #7
Pump out the well??
What kind of a well is this???
Old 10-14-2010, 06:40 AM   #8
Concrete well rings.20 odd ft deep.The elbow to my pump in the house is under water.If the water table was lower I could just take a ladder in there.
Ruud heat pump high pressure switch mikethe ductman HVAC 3 07-28-2010 06:00 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
10 year old well upgrade bjhaffly Plumbing 9 08-23-2009 07:06 AM
how to make a pressure balancing loop gib7464 Plumbing 1 03-25-2006 08:31 PM
