Jet Pump Runs Continually - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2009, 10:37 AM   #1
Jet Pump runs continually
In a home water system, the shallow well jet pump turns on frequently; seems like whereas the pump used to come on at 20 pounds and shut off at 50, it's now keeps the pressure between 45-50. It's fine to have the pressure up all the time but the continual on/off of the pump must be harmful.
So is the problem in the tank or in the pressure switch?
October; I'm still having this problem. It is just that the pump comes on with a slight drop in the pressure, then shuts off, so that the pressure remains high all the time, but the pump is running a lot. Question now is, Is This A Problem With The Pressure Tank or With The Pressure Switch?
Jimbobwe is offline   Reply With Quote
Old 08-04-2009, 11:25 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Deleted
Mike Swearingen is offline   Reply With Quote
Old 08-04-2009, 01:25 PM   #3
Water quality'n pump guy
This means the pump can't build sufficient pressure to cause the pressure switch to shut off the pump.
The tank has nothing to do with it, it is nothing but a wide spot in the water line.
The switch may not be seeing the pressure change in real time due to lagging, meaning that the nipple the switch is plumbed on or, the tubing to the switch, the tubing fittings and the holes they screw into may be blocked, but probably not.
The jet in the pump, or the well if you have a 2 line jet pump, could be partially blocked, you may have a water leak or the water in the well may be much lower than in the past. Or the inlet to the foot valve could be partially blocked.
Are you in a drought?
Gary Slusser
23 years in water treatment and well pumps, 13 years on the 'net helping others to help themselves.
Gary Slusser is offline   Reply With Quote
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Sump Pump cycles 3-8 times each time it runs Delegator Plumbing 2 04-06-2008 01:48 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
