Jet Pump Losing Prime - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 09:47 PM   #1
Jet pump losing prime
I have a 60ft well with a 2 line jet pump, 15ft of water in well. A few months back my pump went bad so I replaced it along with all of the piping and foot valve. I ran schedule 80 pipes so I wouldn't have to worry about the pipes breaking. About a month ago I lost prime in the well, primed it and lost prime again a few days later. Had the same problem and turned out the foot valve was bad so I replaced it. That was 2 weeks ago and here I am again with no water. What could be the problem if I have new pies with no leaks and a new foot valve?
jstring3 is offline   Reply With Quote
Old 07-26-2012, 09:20 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Were you able to get any water out of the pump at all after making the repairs?
did you replace the entire pipe from the foot valve all the way to the pump inlet?
Journeyman Plumber
Old 07-26-2012, 11:16 AM   #3
Replaced both pipes from foot valve to pump, had water for a few months then had to replace foot valve and had water for 2 weeks
Old 07-26-2012, 08:39 PM   #4
Doing it myself
Alan's Avatar
So will the pump produce water if not connected to the house?
Journeyman Plumber
Old 07-26-2012, 08:48 PM   #5
Pretty sure I have figured out the problem, I had 45lbs of pressure in my tank which was causing the pump to become air locked, installed a ball valve and closed it half way and everything seems fine now. Only bad news is that I found out that my tank is leaking water out of the bottom now so I guess that is on the list for tomorrow after work. Thanks for the responses and help
Not sure if trying to prime my well pump correctly. jiggypiggy Plumbing 7 07-06-2012 07:14 AM
pump looses prime, runs forever, burns out PVC pipe noquacks Plumbing 19 06-04-2012 07:16 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
