Jet Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2012, 03:26 PM   #1
Jet Pump
I have a 2 pipe just pump that is acting up. I replace the venturi, foot valve and pipe down in the well and installed a new 1hp motor in the basement. We primed it up and it ran good until we turned on the outside faucet to water the garden and it lost its prime. I have spent several days trying to reprime the pump.
From the pump to the expansion tank I have a ball valve installed, and from the expansion tank to the whole house purifier I have a ball valve. Then it runs thru the UV light and into the the water heater and house.
When I start the pump, it runse about 40 psi with the valve between the tank and the pump closed. When I open it, it loses its prime completely.
Any ideas on what could be wrong?
churchill66542 is offline   Reply With Quote
Old 07-07-2012, 03:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by churchill66542 View Post
...ran good until we turned on the outside faucet to water the garden and it lost its prime. I have spent several days trying to reprime the pump.
How's the water table out there?
Old 07-07-2012, 04:50 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You say the pump is losing it's prime, but at the same time it sounds to me like you're trying to describe something else.
A pump losing it's prime means that there's no water left in the motor, which happens when the water leaks out of the drop pipe back into the well. You've replaced all of that, so either you put something faulty in, a joint isn't holding, or you broke something when you put the pipe back down the well.
Turn off the ball valve AFTER the pressure tank. That part of the system there should run all by itself without having to worry about the rest of the line between the pressure tank and the house.
Do you have a low water cutoff style pressure switch?
Journeyman Plumber
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
