Jacuzzi Whirlpool Tub Faucet Dripping - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2010, 03:35 PM   #1
Jacuzzi Whirlpool tub faucet dripping
Have a drippy faucet, but not able to get the stem out so I can replace the o-ring. There is no nut holding it in and if there is a clip, I have no room to get to it. If anyone has experience with Jacuzzi tubs, please advise what I need to do to get this faucet fixed.
thanks,
mlh
mlh7933 is offline   Reply With Quote
Old 04-17-2010, 10:42 PM   #2
remodeling pro
From this description, it sounds like you have a Jacuzzi factory supplied spout assembly. Jacuzzi makes a special thin wall socket for getting into the faucet. Like you, I was ready to go crazy trying to figure how to repair this faucet, until I discovered the secret. Search for Jacuzzi repair parts on line, and you can see the diagrams to determine exactly which model of faucet you have. They are called "Water Rainbow Spouts", and the exact model is easy to identify because they have diffeent styles of handles. You will see the cylindrical tool shown in the exploded parts diagram.
One source for parts is CCO Whirlpool and Spa Service, but there are numerous others.
troubleseeker is offline   Reply With Quote
Old 04-17-2010, 10:50 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Is it actually a faucet made by jacuzzi, or is it just a tub filler on your whirlpool tub?
Journeyman Plumber
Old 04-18-2010, 10:51 AM   #4
It is a faucet made by jacuzzi. Even the handle has the Jacuzzi name on it. and thanks for the reply...I will look up this socketmlh
Old 04-18-2010, 11:08 AM   #5
I found the thin walled socket. Do you attach a wrench to it or what. Sorry, but not that good of a fix it guy. and would I need to replace the cartridge or is it just an o-ring type of fix. Dont want to order the wrench and then not order something else I need to stop the dripping.. thanks.
mlh
Old 04-18-2010, 04:41 PM   #6
remodeling pro
mlh
It is a cartridge type faucet. Mine was years ago, but I seem to remember that I ordered what was called an "assembly repair kit" that contained everything you need, including the tool, in one package.
Old 04-19-2010, 09:48 PM   #7
I have the cartrige repair kit ordered and should get it later this week. I hope that it will be simple to remove and replace the cartridge. I do appreciate the advice that I have received on this topic...
mlh
Outside faucet still dripping watercub Plumbing 11 08-17-2016 12:24 PM
Jacuzzi Whirlpool bath floor construction eemc2 Building & Construction 6 02-03-2010 10:14 AM
How to fix a dripping shower faucet? walds11 Plumbing 18 12-21-2009 08:17 PM
Hole in Whirlpool Tub (inside jacuzzi) cm3putter Plumbing 1 10-07-2009 10:44 AM
Dripping two handle bathroom sink faucet? hzemall Plumbing 1 09-06-2009 07:51 PM
