Jacuzzi Tube Does Not Flow Water!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-16-2011, 09:14 PM   #1
Jacuzzi tube does not flow water!!
I have a jacuzzi tube in my master bath that does not flow water. The pump turns on and runs, just will not flow water. Is it possible that the impeller is stripped from the motors shaft? I just don't understand how it can run, but not flow water. Any sugestions?
Thanks for your time,
Nate
Nate53 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
