Jacuzzi Cleaning/maintenance? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2008, 04:00 PM   #1
newer than a newbie...
Rewards Points: 87
Jacuzzi cleaning/maintenance?
Hi All.
I hope you can help me. We have bought a house that the prior owners said came with the Jacuzzi. It hasn't been used since 1995, so as we took posession we tried it out and it seemed to work, but there was a lot of black gunk/dirt in the jets.
I am wondering how we can clean/disinfect the tub/jacuzzi on a regular basis? Can anyone provide suggestions?
Thanks so much.
mcvane is offline   Reply With Quote
Old 03-31-2008, 05:04 PM   #2
Send a message via AIM to Marlin
Is this a regular jacuzzi or a jacuzzi tub? If it's a regular jacuzzi I'd go to a store that sells jacuzzis and jacuzzi supplies. They should be able to tell you the correct process for cleaning it out and maintaining it as well as sell you the correct chemicals.
Marlin is offline   Reply With Quote
Old 03-31-2008, 06:14 PM   #3
Rewards Points: 87
Hi There.
Thanks for your reply.
It is a jacuzzi/bathtub, so it's a combination you could say. It's the only bath-tub in the house, so we have no other alternatives (except for a shower stall).
Old 04-01-2008, 07:46 AM   #4
Rewards Points: 1,188
I'd fill it and run it with bleach. The black gunk is mouldy stagnant water that was left in the plumbing each time the tub was filled and the jets not used.
If this is the kind of "garden tub" builders put into homes to "upscale" them, with the jets in the sidewalls of the tub and not the bottom, you're going to find these are just expensive gimmicks that have no thereputic value whatsoever.
LawnGuyLandSparky is offline   Reply With Quote
Old 04-01-2008, 03:00 PM   #5
I'd do a Google search, or better yet if their is a company name on the tub contact them. Bleach may harm the tub (or it may not) I'm sure their is a prescribed way to do this.
Old 09-01-2008, 01:55 PM   #6
I have a jacuzzi tub and fill it full of hot water and 1/2 cup of Cascade run 10 min
Originally Posted by mcvane View Post
Hi All.
Thanks so much.
Lindadelle is offline   Reply With Quote
Jacuzzi Tub fengler19 Electrical 6 02-28-2008 08:36 PM
Jacuzzi - Where to start? m1a-b3r311 Plumbing 2 01-02-2008 05:52 PM
Replace Jacuzzi with shower? mustanger Remodeling 4 11-15-2007 11:19 AM
Jacuzzi Hot Tub jm1438jh Electrical 2 11-10-2007 11:22 AM
