Jacuzzi Brand Tub Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2010, 08:57 PM   #1
Jacuzzi brand tub leaking
I have a leak, I think if is from or around one of the jets....but havn't put air and soap bubbles on it. any ideas for analysis and fix
squirtdad is offline   Reply With Quote
Old 12-09-2010, 01:12 AM   #2
FTRR
Pull your access panel, run the water, pump off, and visually inspect for leaking, if you see no leaks turn the pump on and inspect again, you should be able to find the leak visually you may need an inspection mirror for the hard to see areas. Once you determine what is leaking then we can talk repair.
FamilyTreeRemod is offline   Reply With Quote
The Following User Says Thank You to FamilyTreeRemod For This Useful Post:
squirtdad (12-09-2010)
Old 01-11-2011, 02:33 PM   #3
Ok, I did some more debugging.....and I found the source of the leak, it is a half ball valve (plastic half ball, o rings) with what looks like a solenoid attached. the valve is at the end of a pvc pipe that angles down, and I am guessing is related to the drain over flow. There is no other plumbing attached beyond the valve/solenoid...it terminates the pipe. The tub it self is a jacuzzi J-Sha.
any ideas (I am searching around alsi)
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Jacuzzi issue Marvin Gardens Plumbing 1 10-28-2008 08:05 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
Replace Jacuzzi with shower? mustanger Remodeling 4 11-15-2007 12:19 PM
