Jackhammering - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2011, 01:07 PM   #1
Jackhammering
We have lived in our home about 17 years, built new,recently I have had this problem with one of three identical Moen faucets where there is a loud noise in the hot water side and the faucet will shut off entirely. I replaced the faucet with a new Moen and have the same identical problem. Anyone have an answer?
lewisnh is offline   Reply With Quote
Old 02-14-2011, 01:15 PM   #2
Steeler99's Avatar
sounds like air in the pipes to me...which, I'd turn on all the faucets in the house with hot water....once they all run good for a minute or two, then turn them off one by one by starting at the highest faucet and work your way down. If the kitchen sink has a high arch to it, do that before any bathrooms on the same floor. I hope that solves your problem for ya, Im curious to see what others suggest
Steeler99 is offline   Reply With Quote
Old 02-14-2011, 08:20 PM   #3
Are there isolating valves under the sink? Sounds like a loose washer to me.
Air in the pipes? Air would just be bled out by city pressure.
Marioisaplumber is offline   Reply With Quote
Old 02-14-2011, 08:57 PM   #4
Experienced
Jackofall1's Avatar
Might want to check the isolation valve under the sink, sounds like the seat has broken loose and is floating in the valve body.
Mark
