J-shaped Paintable Pipe Hangers - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-01-2008, 05:03 PM   #1
Rewards Points: 1,062
Question
J-shaped paintable pipe hangers
i have 3/4 in black pipe exposed in the living room and would like to replace the existing couple of hanger straps, which are unsightly, with some J-shaped paintable hanger straps, kind of like i've seen the make for PVC. they would fit more seamlessly into the visual setting. any idea where i could get such hangers ?
Old 09-01-2008, 05:09 PM   #2
the Musigician
DangerMouse's Avatar
pretty much any of the 'big box' stores and most hardware stores should have them. they even have fancy scrollwork ones if that'd fit better. i'm just curious what type of black pipe would be showing in the living room???
DM
Old 09-01-2008, 07:03 PM   #3
Registered User
Termite's Avatar
Most of the time, black pipe is gas. Gas is not typically hung with plastic j-hangers. They just aren't made for that purpose. It is too heavy in my opinion, and should be hung with metal hangers that will not let the pipe deflect at all, which stresses the connections.
Sioux Chief basically makes all the hangers used in plumbing. You can get their products at Home Depot and basically all home centers and plumbing stores. Here's a link to their full line of hangers.....
http://www.siouxchief.com/Frm_MS.cfm
Old 09-01-2008, 07:05 PM   #4
i was looking for metal ones - more heavy duty. i used the plastic ones as a comparison.
Old 09-01-2008, 07:06 PM   #5
on its way to the appliance, the pipe coming into the house from the street. leaving exposed brick (and consequently pipe) for the aesthetics.
Old 09-01-2008, 11:50 PM   #6
Registered User
Termite's Avatar
There are metal ones out there. Let me see what I can find online........
Old 09-01-2008, 11:58 PM   #7
Registered User
Termite's Avatar
OK. Not a great picture but they'd sure work. These hangers are fastened around the pipe and hang vertically from a section of threaded rod. On the ceiling you mount a small cast iron flange that the threaded rod screws into...A couple screws mount it. They're widely used in commercial construction (not a home center more than likely) and look pretty clean. Especially if you're going for that brick building with pipes exposed look! Any plumbing supply house should have them.
Here's a pic of the part that goes around the pipe that the threaded rod screws into...
http://www.grainger.com/Grainger/items/1RVD6
Old 09-02-2008, 01:39 AM   #8
thanks termite, i think this will do ...
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
