Old 09-13-2010, 04:33 PM   #1
Issue with ancient 6" Clay sewer pipe
First off, thanks for any help you may provide. Been lurking for a bit, butnow could use some help.
Basically I have a 1913 home with a basement and sub basement.
Under the upper basement floor there is 6" clay sewer pipe.
After installing all new plumbing I ran some water, and it came out of the concrete wall that separates the upper and lower basement...if that makes sense.
I cut a 3' square around the leak in the concrete wall were it was leaking.
I discovered what looks like a huge 6" Clay P trap....in which has an open end that came to the wall and was brick and mortared closed. I dug all the way around the pipe and it was completely loose. I pull it out and now have a fresh end of the 6" Clay sewer. I cant re use the old pipe as its now cracked and broken.
I cant seem to find a 6" ID compression plug.
I have been told by 2 guys to use a trash bag, put it in the pipe and fill with mortar thus making a solid plug. Is this something that is proper? (realizing its an old home, and there is plenty of unproper stuff )
Thanks again for any help!
GripnDeWALT is offline   Reply With Quote
Old 09-13-2010, 05:00 PM   #2
steveel's Avatar
Not sure I understand. Why do you think it started leaking in the first place? Did your new plumbing disturb this area somehow?
steveel is offline   Reply With Quote
Old 09-13-2010, 05:12 PM   #3
Ultimately it looks like the "p trap" looking piece had seperated from the rest of the pipe over time. Judging how the last owners left the house, they probably just let it leak.
PHP Code:
[PHP
[/PHP]
Old 09-13-2010, 06:38 PM   #4
If I understand this right it sounds like the new pipe WAS connected to this line, what is the new plumbing connected to now?
braindead is offline   Reply With Quote
Old 09-13-2010, 06:44 PM   #5
The question is: how do I plug a 6" clay sewer pipe. Everyone says a 6" compression plug is out there but I can't find one anywhere. Is there another method?
Old 09-13-2010, 06:58 PM   #6
I was trying to confirm that you were not plugging a line that was still in service, if you are sure the idea of using mortar is fine, just use something like a mortar bag, or a paper trash bag before you seal it up.
Old 09-13-2010, 08:13 PM   #7
I would get a 6"clayx4"plastic fernco, insert a small piece of 4" plastic pipe, and glue a cap to the plastic. The lowes in my area sells the fernco, or go to just about any plumbing supply house to get it
the_man is offline   Reply With Quote
Old 09-13-2010, 08:50 PM   #8
Owner
LateralConcepts's Avatar
PHP Code:
[php
[/php]
I'm still a bit confused yet interested in what you're talking about. Did you try to post a picture?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Old 09-13-2010, 08:59 PM   #9
Sounds like an abandoned building trap. I'm betting that the line is backing up, since it shouldn't have any water in it
Old 09-13-2010, 09:02 PM   #10
Owner
If it's abandoned why is all the plumbing tied to it?
Lateral
(208) 818-8241
Old 09-13-2010, 09:09 PM   #11
dunno, but if the building drain ran to it I don't think he'd be asking about a cap I think he'd be asking how to connect em maybe he's got a new/different sewer that ties in with that one somewhere. I'd be curious to see some pics too
Old 09-13-2010, 09:14 PM   #12
Owner
Hmm well grab the popcorn
Lateral
(208) 818-8241
Old 09-13-2010, 09:23 PM   #13
i'll grab a beer too
Old 09-13-2010, 09:26 PM   #14
This sounds like a viable option. Wasn't aware of such an adaptor. Just unsure of how it would slip over the clay pipe because it has a "lip" around it.
Others: no abandoned house here.
New plumbig refers to water: not the drain under the concrete. Guess I should have been more specific.
Ill get pics tomorrow, as I do not reside there yet to get the remodel done.
Old 09-13-2010, 09:35 PM   #15
The bell would have to come off. There is a tool to do this, called chain cutters. Rental yards have em, or you can use a diamond blade on an angle grinder. When I said abandoned, I meant the sewer line, not the building. Was it hooked up to anything before? Better hurry, or I'll be too drunk to answer
Vent pipe cover? KE2KB Plumbing 2 04-16-2010 07:43 AM
4" gutter -> 3" sewer pipe amakarevic Plumbing 4 08-22-2009 10:48 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
waste pipe leveling issue amakarevic Plumbing 9 03-27-2008 06:12 PM
Drainage issue from heating system and washing machine susandlynn Plumbing 1 11-17-2007 03:28 PM
