-   -   Issue with ancient 6" Clay sewer pipe (http://www.diychatroom.com/f7/issue-ancient-6-clay-sewer-pipe-81353/)
GripnDeWALT 09-13-2010 03:33 PM
First off, thanks for any help you may provide. Been lurking for a bit, butnow could use some help.
Basically I have a 1913 home with a basement and sub basement.
Under the upper basement floor there is 6" clay sewer pipe.
After installing all new plumbing I ran some water, and it came out of the concrete wall that separates the upper and lower basement...if that makes sense.
I cut a 3' square around the leak in the concrete wall were it was leaking.
I discovered what looks like a huge 6" Clay P trap....in which has an open end that came to the wall and was brick and mortared closed. I dug all the way around the pipe and it was completely loose. I pull it out and now have a fresh end of the 6" Clay sewer. I cant re use the old pipe as its now cracked and broken.
I cant seem to find a 6" ID compression plug.
I have been told by 2 guys to use a trash bag, put it in the pipe and fill with mortar thus making a solid plug. Is this something that is proper? (realizing its an old home, and there is plenty of unproper stuff :laughing: )
Thanks again for any help!
steveel 09-13-2010 04:00 PM
Not sure I understand. Why do you think it started leaking in the first place? Did your new plumbing disturb this area somehow?
GripnDeWALT 09-13-2010 04:12 PM
Ultimately it looks like the "p trap" looking piece had seperated from the rest of the pipe over time. Judging how the last owners left the house, they probably just let it leak.
PHP Code:
[PHP
[/PHP]
braindead 09-13-2010 05:38 PM
If I understand this right it sounds like the new pipe WAS connected to this line, what is the new plumbing connected to now? :huh:
GripnDeWALT 09-13-2010 05:44 PM
The question is: how do I plug a 6" clay sewer pipe. Everyone says a 6" compression plug is out there but I can't find one anywhere. Is there another method?
braindead 09-13-2010 05:58 PM
I was trying to confirm that you were not plugging a line that was still in service, if you are sure the idea of using mortar is fine, just use something like a mortar bag, or a paper trash bag before you seal it up. :huh:
the_man 09-13-2010 07:13 PM
I would get a 6"clayx4"plastic fernco, insert a small piece of 4" plastic pipe, and glue a cap to the plastic. The lowes in my area sells the fernco, or go to just about any plumbing supply house to get it
LateralConcepts 09-13-2010 07:50 PM
PHP Code:
[php
[/php]
I'm still a bit confused yet interested in what you're talking about. Did you try to post a picture?
the_man 09-13-2010 07:59 PM
Sounds like an abandoned building trap. I'm betting that the line is backing up, since it shouldn't have any water in it
LateralConcepts 09-13-2010 08:02 PM
If it's abandoned why is all the plumbing tied to it?
the_man 09-13-2010 08:09 PM
dunno, but if the building drain ran to it I don't think he'd be asking about a cap I think he'd be asking how to connect em :laughing: maybe he's got a new/different sewer that ties in with that one somewhere. I'd be curious to see some pics too
LateralConcepts 09-13-2010 08:14 PM
Hmm well grab the popcorn :huh:
the_man 09-13-2010 08:23 PM
i'll grab a beer too :drink:
GripnDeWALT 09-13-2010 08:26 PM
This sounds like a viable option. Wasn't aware of such an adaptor. Just unsure of how it would slip over the clay pipe because it has a "lip" around it.
Others: no abandoned house here.
New plumbig refers to water: not the drain under the concrete. Guess I should have been more specific.
Ill get pics tomorrow, as I do not reside there yet to get the remodel done.
the_man 09-13-2010 08:35 PM
The bell would have to come off. There is a tool to do this, called chain cutters. Rental yards have em, or you can use a diamond blade on an angle grinder. When I said abandoned, I meant the sewer line, not the building. Was it hooked up to anything before? Better hurry, or I'll be too drunk to answer :drink: :drink: :drink: :lol:
