ISO Soldering Gear/equipment. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2007, 11:24 AM   #1
Rewards Points: 264
ISO Soldering gear/equipment.
I picked up a soldering kit for my small diy jobs around the house, but have a couple questions on other tools that I might want to add for future repairs.
Torch - I had 2 propane torches I was using, and both had simmilar but different style tips on them. The first one I think was just a generic torch for general use, the other was in an old soldering kit someone gave me. The latter seemed to burn alot hotter than the first one. Is there a certain tip that works better than others?
Gloves - What do you reccomend for gloves? I was using leather work gloves making the assemblies, but kept having to run pieces under the faucet to cool them off.
Besides the basics, what else would you reccommend?
What I have so far: Pipe cutter, mini pipe cutter, propane torch, 1/2 brush, sand paper, solder/flux, cable type pvc cutter.
Jeekinz is offline   Reply With Quote
Old 04-16-2007, 02:14 PM   #2
Rewards Points: 150
I'd also recommend getting a Kevlar fireproof soldering cloth.
It takes less time to do a thing right than it does to explain why you did it wrong.
-Henry Wadsworth Longfellow
beer_geek is offline   Reply With Quote
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 01:08 PM
Soldering 1/4 turn valves Manuel6 Plumbing 2 12-11-2006 03:32 PM
Cold tip soldering gun??? justdon Tools 3 01-21-2006 07:41 PM
