Island Sink & Washer Properly Vented - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2011, 10:34 PM   #1
Island sink & washer properly vented
We are remodeling a 40 year old home in Missouri. Can a licensed plumber review the attached sketch to be sure we will have no drainage problems and that everything will meet code. Missouri uses IRC, we are in the country, so no city code requirements.
The vent we want to use is in the center of the house, we want to move the sink so it is in an island overlooking the great room. The laundry is in the basement and uses the same vent. The sink and washer will drain into the same drain, that then connects to the main under the concrete.
See drawing attached for more detail.
chskc is offline   Reply With Quote
Old 01-30-2011, 11:16 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 542
Don't know Missouri code but by UPC you can't do what you have drawn.
Old 01-30-2011, 12:19 PM   #3
Can you give me suggestions, changes, more info ?
Old 01-30-2011, 02:12 PM   #4
Plumber
Rewards Points: 542
for starters, you cannot tie another vent into the island foot vent.
your washing machine has a s trap- not allowed
vertical sink drain cannot tie into that vertical vent (which as drawn, is not a proper vent) connect it to the stack.
I am required to use 2" drains for washing machines and kit sink. I.5" vents
The island illustration that you found originally was prolly the only legal way. Don't modify the foot vent
Tags
island sink , vent , washer
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
Dish washer not cleaning properly cliffordjuli@yahoo.com Plumbing 5 10-19-2008 06:47 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
