Irrigation Pump Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2012, 08:12 AM   #1
RustyRealtor's Avatar
Rewards Points: 287
Hello Everyone,
I moved into a house in FL which has an irrigation pump in the garage. The pump is leaking at the threads where the PVC enters and exits the pump (two leaks). I have seen this on other pumps as well. It is as if the male threads bottom out on the female threads before being truly tight. I will have to cut the PVC to remove the old fittings and then replace with identical fittings.
Why do the threads bottom out?
Should I simply add a lot more teflon tape to the male thread?
Would iron pipe be a better fit?
Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Basement leak. Sump pump or French drain? Jmcnyc General DIY Discussions 2 08-14-2011 10:26 AM
irrigation pump shutdownMy Sta-rite 2 HP centrifugal self priming single phase 240V i Oly Electrical 7 06-17-2010 10:44 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
