Iron Pipe Threading - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-11-2009, 04:51 PM   #1
Iron Pipe Threading
I bought iron pipe from Home Depot and i needed several 16" lengths. I was told that their Rigid pipe threading machine would not thread this length as the pipe had to reach both front and rear jaws, but Rigid's website seems to indicate differently. Does anyone know if this is true before i have to rent a pipe threading ratchet and hand thread the pipes???
tvwav is offline   Reply With Quote
Old 03-11-2009, 08:08 PM   #2
Id just ask the rental place. Or what might be cheeper is find a hardware store that threads pipe. I know that in my neck of the woods the small hardware stores are the only ones that offer this. If you have never threaded pipe before be careful no to cut the treads to short.
lilh2o3 is offline   Reply With Quote
Old 03-11-2009, 09:37 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
You need 16" nipples threaded? Hell, they can be threaded all day long at that length. Of course it may be their company policy not to attempt to thread anything shorter than say 24" because....well I dont know why...go figure, eh? The simple fact is that yes, you can thread 16" lengths on that kind of machine.
JDC is offline   Reply With Quote
Old 03-11-2009, 10:00 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Heck you only need 3 threads
one to start, one to hold and one for the inspector...LOL
Call a local plumber and see if they will thread the pipe.
Old 03-11-2009, 10:49 PM   #5
Idiot Emeritus
Rewards Points: 1,492
If I got a dime for every pipe I've threaded that didn't reach both jaws on the threader, I could have retired years ago!
That's got to be one of the dumbest things I've ever heard. They sure don't have much faith in their employees, do they?
You could likely rent a hand threader and a pipe vise fairly cheap. If the pipe is 1" or less, it threads easily, 2" is a bit tougher.
Rob
micromind is offline   Reply With Quote
Old 03-12-2009, 02:20 AM   #6
Thanks for the info. I was pretty sure that they were incorrect about the machine. Of coarse, i can't make them thread the pipe, but i hate to spend $27 (and 45 min. each way) to rent a thread kit and vice stand to do what they could and should do for the price of the pipe. As far as threading with a ratchet, i did plenty of that as a young man and enjoyed every minute of it!
Old 03-12-2009, 08:27 AM   #7
Rewards Points: 20
I would try asking a different employee if he can do it. If not I would talk to the manager and find out why they can't do it. Last resort I would buy the pipe threader that they sell and use it and then take it back, if they have a lenient return policy, the one around me does. And normally I wouldn't "use" a store like that but if they don't want to do the service for you that they offer I wouldn't feel bad about doing it.
ponch37300 is offline   Reply With Quote
Old 03-12-2009, 08:40 AM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,336
Isn't 16" a stock length at HD?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-12-2009, 11:19 AM   #9
The employee you talked to either did not want to do the threads, or was not knowledgeable of the process. The rear "jaws" on a pipe treader are to keep long lengths of pipe straight when the machine is on. They do not even have teeth.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-16-2009, 01:33 AM   #10
Rewards Points: 372
Why not just get some nipples and connectors, make the lengths that you need. Remember, you lose 7/16" each joint. We installed a fire system last week and only made 4 threads. (Newby cutting threads, we needed 1 thread, he needed to practice on 3 threads) The rest of the job was faster using nipples and couplers. The system we installed last week used much longer piping & we did cut and thread that job. However, this Thursday we used a groove lock and a Roughneck on 3 " pipe. Different pipe, different joining methods.
fireguy is offline   Reply With Quote
Cast iron pipe broken? tervic Plumbing 6 02-18-2009 06:23 PM
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
Threading black iron pipe? sandyman720 Plumbing 3 03-12-2007 06:50 PM
