Iron Pipe Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-13-2007, 12:28 PM   #1
iron pipe fittings
Hello all. I'm replacing the stop valves in my downstairs bath. Both are attached to iron pipes that go into the basement. Although I have done lots of plumbing work with copper and compression fittings, I have never work with galvanized IP. I'm a little bit concerned with getting the valves off the nipples but what I'm even more concerned with is the elbow below the floor that the hot water nipple is in. It's rusted on the outside and I think it needs to be replaced. As far as replacing IP fittings how tight should they be and what is best to use on the threads? Also what are the chances they end up in the same position as the fittings I'm replacing?? thanks
farrington135 is offline   Reply With Quote
Old 07-13-2007, 09:16 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
farrington,
I've been an avid DIYer for more than 50 years, and one of the most frustrating things that I've ever worked with is old galvanized pipe (which is what my parents had way back when and what I "learned" on).
When working with old galvanized, you will always need two good pipe wrenches...one for backup to hold what you're trying to screw something out of or into without letting it move at all, and one to turn what you want to remove or screw on.
Depending upon the size of the pipe and the rusted "seize" of the fitting, if you can, sometimes it is helpful for heat it with a torch if you can do it safely. If you can't heat it, then sometimes it helps to soak it in a solvent overnight, such as WD-40. You can use cheater pipes on the wrenches if necessary (pipe large enough to slip over the end of the pipe wrench handles to give you more leverage).
Use 2-3 flat wraps of teflon tape on the male threads wrapped clockwise only as the threaded end faces you, to reconnect the new fittings.
It usually is best to back off from the worst of the rusted fittings to get to a fitting in a better condition, to start replacing old galvanized sections of pipe.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Threading black iron pipe? sandyman720 Plumbing 3 03-12-2007 07:50 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
iron pipe fittings Talman48 Plumbing 2 01-10-2007 06:11 AM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
