Iron Pipe Fittings - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2007, 10:13 PM   #1
iron pipe fittings
Can you tell me what is meant by malleable, in reference to pipe fittings?
Talman48 is offline   Reply With Quote
Old 01-10-2007, 01:14 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
The def makes no ryme or reason, guess they wanted a cool word to use at the time.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-10-2007, 05:11 AM   #3
At one point it refered to the type of Iron used to make them...... doesn't apply much anymore
mdlbldrmatt135 is offline   Reply With Quote
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 08:20 PM
iron pipe fittings farrington135 Plumbing 1 07-13-2007 08:16 PM
Threading black iron pipe? sandyman720 Plumbing 3 03-12-2007 06:50 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
