Iron Gas Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2010, 03:08 PM   #1
Rewards Points: 640
Iron gas line
I have a black cast iron nat. gas line running down the length of my house which I need to extend, the end right now stops at the furnace, but I need to extend it about 4 ft past that to move my water heater... (i'm going to have a pro help with this since nat gas scares me...) but in preperation for this I was wondering what are the clearances you need around a line like this? it will have to run above a HVAC trunk line to get where its going, right now it goes about 6 inches into the space above it so part already goes there, but they have it capped off at that point... can I run this the rest of the way? it has about 2 inches of clearance right now on the bottom and right side and about 8 inches on the left side and about 1/2" clearance above...
do I need to move the HVAC trunk line some or are these clearances fine?
BlueBSH is offline   Reply With Quote
Old 11-16-2010, 06:06 PM   #2
Rewards Points: 1,216
Run it no clearance necessary. The pro will tell you.
COLDIRON is offline   Reply With Quote
Old 11-16-2010, 07:15 PM   #3
HVAC / Plumbing
probably black iron (steel) never seen cast iron gas piping inside a home
kenmac is offline   Reply With Quote
Old 11-17-2010, 06:38 AM   #4
Licensed Master Plumber
What kind of licensed pro is going to be willing to "work with you" ?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 11-17-2010, 07:15 AM   #5
Most localities do not like homeowners or other trades doing anything to gas lines, too dangerous. Doing it wrong can cost lives. Have a real licensed pro look at it.
Old 11-17-2010, 07:32 AM   #6
Don't worry about the prep work , let the pro do everything.
Old 11-17-2010, 08:09 AM   #7
Rewards Points: 640
One that is related to me?
but by work with me I mean they will do that while I do something else, I am doing the copper work to move water lines while they do the more dangerous work aka moving the nat gas line
Old 11-17-2010, 08:10 AM   #8
Rewards Points: 640
yeah, its steel, We always just called it iron because of how it looks
Old 11-17-2010, 08:11 AM   #9
Rewards Points: 640
ours doesn't, but like I said I'm having someone else do the line work, I was just going to do any prep work that would be needed for clearances around the line if any
Old 11-17-2010, 09:22 PM   #10
HVAC / Plumbing
Just don't go into supply house & ask for cast iron gas pipe to pipe your house. He/she may look at you like this
Old 11-17-2010, 10:25 PM   #11
Rewards Points: 640
that's why I have someone else doing that part for me
Old 11-18-2010, 07:12 AM   #12
Most supply houses I know of look at you like that no matter what you go in for.
Old 11-18-2010, 06:36 PM   #13
Rewards Points: 150
Most of the ones I go into look at you like this LOL
braindead is offline   Reply With Quote
Old 11-19-2010, 06:58 AM   #14
YEAH!!!!!!
Gas line extension - black iron or copper?? Joshua77 Plumbing 27 10-24-2013 03:34 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Questions regarding AC coil condensate line lassiter1979 HVAC 1 03-14-2010 09:47 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Installing drain line parcially upgrade. jbravo8212 Plumbing 8 02-19-2008 06:12 PM
