-   -   Iron gas line (http://www.diychatroom.com/f7/iron-gas-line-86881/)
BlueBSH 11-16-2010 03:08 PM
Iron gas line
I have a black cast iron nat. gas line running down the length of my house which I need to extend, the end right now stops at the furnace, but I need to extend it about 4 ft past that to move my water heater... (i'm going to have a pro help with this since nat gas scares me...) but in preperation for this I was wondering what are the clearances you need around a line like this? it will have to run above a HVAC trunk line to get where its going, right now it goes about 6 inches into the space above it so part already goes there, but they have it capped off at that point... can I run this the rest of the way? it has about 2 inches of clearance right now on the bottom and right side and about 8 inches on the left side and about 1/2" clearance above...
do I need to move the HVAC trunk line some or are these clearances fine?
COLDIRON 11-16-2010 06:06 PM
Run it no clearance necessary. The pro will tell you.
kenmac 11-16-2010 07:15 PM
probably black iron (steel) never seen cast iron gas piping inside a home
NHMaster 11-17-2010 06:38 AM
What kind of licensed pro is going to be willing to "work with you" ?
Just Bill 11-17-2010 07:15 AM
Most localities do not like homeowners or other trades doing anything to gas lines, too dangerous. Doing it wrong can cost lives. Have a real licensed pro look at it.
COLDIRON 11-17-2010 07:32 AM
Don't worry about the prep work , let the pro do everything.
BlueBSH 11-17-2010 08:09 AM
One that is related to me? :huh:
but by work with me I mean they will do that while I do something else, I am doing the copper work to move water lines while they do the more dangerous work aka moving the nat gas line
BlueBSH 11-17-2010 08:10 AM
yeah, its steel, We always just called it iron because of how it looks :laughing:
BlueBSH 11-17-2010 08:11 AM
ours doesn't, but like I said I'm having someone else do the line work, I was just going to do any prep work that would be needed for clearances around the line if any
kenmac 11-17-2010 09:22 PM
Just don't go into supply house & ask for cast iron gas pipe to pipe your house. He/she may look at you like this:eek:
BlueBSH 11-17-2010 10:25 PM
that's why I have someone else doing that part for me :laughing:
COLDIRON 11-18-2010 07:12 AM
Most supply houses I know of look at you like that no matter what you go in for.
braindead 11-18-2010 06:36 PM
Most of the ones I go into look at you like this :huh: LOL
COLDIRON 11-19-2010 06:58 AM
YEAH!!!!!!:thumbsup::thumbsup::thumbsup::thumbsup: :thumbsup:
