Iron Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2013, 11:15 PM   #1
Rewards Points: 208
Iron Filter
What's the best whole house iron filter i can buy for $1,300?
Which brand is the most popular?
Scully is offline   Reply With Quote
Old 07-08-2013, 11:43 PM   #2
Water Treatment
Rewards Points: 850
You are going to need to answer some simple questions.
Flow rate from the well.
Flow rate needed in the house.
Iron level in ppm.
Ph level
How much maintenance are you planing on for any given year?
It is not as simple as popular or cheap...
It is still a puzzle when people spend big bucks for every thing else in the house and then look for the cheapest water treatment going.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
Scully (07-09-2013)
Old 07-09-2013, 06:40 AM   #3
Rewards Points: 208
Iron level in ppm.
Ph level
i see your points. does it defeat the purpose of an iron filter if the inside of well casing is rusty and the water line from the well is galvanized steel?
Old 07-09-2013, 12:14 PM   #4
Water Treatment
Rewards Points: 850
It would be a very good idea to have a well driller do service to the well and pump.
Test the pump for out put and flow , and work over the well as there could be so much build up that any water test will have false information.
If it can be done it would be good to replace the line from the pitless to the house, some thing that you can ask the well driller.
Doing the above could be your fix, if not then you know some facts about the well and the water test will be a more truthful one, then you can get the Right Equipment for what the water quality.
Black material in water filter Sartrean Plumbing 4 03-09-2012 05:31 PM
iron in water, filter needed? ugabulldog Plumbing 2 11-09-2010 03:46 PM
chemical free iron filter Buff35 Plumbing 1 08-02-2010 12:50 PM
History of Lomonaco's Iron Concepts & Home Decor John Lomonaco Introductions 0 11-08-2009 10:39 AM
Water softener & Iron filter drain DSKUP Plumbing 3 02-17-2009 10:14 AM
