"Invisible" Leak In Bathroom... - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2011, 02:36 PM   #1
Unhappy
"Invisible" leak in bathroom...
Multifamily house; the plumbing for the 3rd floor tub/shower exists above the 2nd floor master BR. After tearing down the BR ceiling for unrelated reasons, I discovered that the 3rd floor bath has been leaking for a very long time (long enough to turn the piece of hardwood floor onto which the leak is falling black). The cast iron pipes still exist, but were replaced with ABS some time ago (I just purchased the 99-yr-old home in August).
It's a relatively modern tub (ex. not cast iron). The current tenant says the "tub" sometimes "makes a creaking noise." The bathroom has a splash guard between the wall and the tub, so water is not spilling over the side of the tub and seeping through the floor directly. I re-caulked where the faucet emerges from the wall, as that was loose...but the leak still exists.
It would appear as though water is somehow getting onto the top lip of the tub (in the wall), running to the front edge, and then running down the wood in the wall. Once the wood is saturated, the water starts falling onto the ceiling below.
My dad and I have had our heads jammed up into the floor looking for the leak for about 60 combined minutes so far with a variety of flashlights and groping around with our hands. I took a 15 minute shower while Pops looked/felt around, and he couldn't feel any water on the top lip of the tub (despite watching water fall at the same time)...so perhaps that theory is partially disproved. It doesn't appear as though any pipe is leaky, or that any part of the tub is cracked...
I've also recaulked the "splash guard," and the faucet's knob (as well as the faucet a 2nd time). I haven't yet recaulked the front edge of the tub, but again dad couldn't feel any water up there so I'm not sure whether that's worthwhile.
I'm at a loss. I'm trying to avoid calling in a plumber who also can't see any leak, and redoing the entire 3rd floor bath (or cutting a hole in the 3rd floor bedroom wall to access the back of the shower, as I have tenants there right now). Any ideas for other possible things to check, or solutions?
Attached is a rudimentary drawing...unfortunately I am without a decent camera right now.
Mustang is offline   Reply With Quote
Old 10-09-2011, 03:19 PM   #2
AlbacoreShuffle's Avatar
Does it only leak when taking a shower, and not when the tub is used ?
If so it could be the riser going from the faucet to the shower head.
AlbacoreShuffle is offline   Reply With Quote
The Following User Says Thank You to AlbacoreShuffle For This Useful Post:
oh'mike (10-09-2011)
Old 10-09-2011, 03:58 PM   #3
Mark Potter's Avatar
Rewards Points: 150
What's behind the shower Wall? Anything? Firewall, closet, bedroom, is the tub tiled or 3 or 4 piece tub?
H|P Capital
Mark Potter is offline   Reply With Quote
Old 10-09-2011, 06:33 PM   #4
No one takes baths, so I'm going to go with shower only. That suggestion was made by someone else as well; will have to look again at that pipe.
Bedroom; hence my hoping to avoid tearing down that wall. The tub is tiled.
Old 10-09-2011, 06:57 PM   #5
Rewards Points: 150
Ok is there a closet in bedroom behind shower wall.
Did you check the shower head from shower make shore not travailing back be behind wall?
It could be the adapter the shower are comes out of.
H|P Capital
Old 10-09-2011, 07:17 PM   #6
No, the shower wall is adjacent to the bedroom wall. BR closet is across the room.
I have not removed the shower head yet. Another forum suggested this, which I will try tomorrow: Remove the the tub spout and the shower head and cap the shower arm and the nipple stubbed out for the tub spout. Then turn on the Valve.
Old 10-09-2011, 08:55 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I would say cap the tub spout first.
Then turn on valve to fill shower riser with water.
Then turn off valve.
cap shower head.
Turn valve back on.
This will ensure that you don't miss a small leak due to the fact that the riser will be completely full of air at first.
Journeyman Plumber
Old 10-09-2011, 09:41 PM   #8
Rewards Points: 150
cap shower head.
Turn valve back on.
He is still going to have to look behind back wall with this method no?
H|P Capital
Old 10-09-2011, 10:00 PM   #9
Doing it myself
Alan's Avatar
H|P Capital
Not necessarily. If this method produces the leak he is seeing, then he's going to have to tear apart the wall to make the repair anyway
If the leak doesn't occur while performing this test, no wall demolition is needed at this time, and we can move on to a different test.
To the OP, have you checked the overflow on the tub? Sometimes people turn them upside down to "increase water level in the tub" which doesn't work anyway, and usually the only thing that it does is cause the overflow to leak when someone is bathing OR showering. I'm not choosing this problem as my guess, due to the fact that you say it's hitting the top surface of the tub before tracking down.
The other thing that commonly occurs is that the tub spout (if it's one with an o-ring) gets a tear in the o ring during installation, and as someone is showering, the water is blowing past the o ring and straight through the hole in the wall. I hope for your sake that it's THIS, as you won't need to demo anything to make the repair.
Journeyman Plumber
Old 10-09-2011, 10:10 PM   #10
Rewards Points: 150
Wow thanks for that explaining how that test works. Now this is a adapter cap that you have to get right both male and female for the shower arm goes in?
H|P Capital
Old 10-10-2011, 12:55 AM   #11
Doing it myself
Alan's Avatar
H|P Capital
What?
Journeyman Plumber
Old 10-10-2011, 06:30 AM   #12
Rewards Points: 150
What?
Yeah you said to cap each end tub spout and riser
H|P Capital
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 10:54 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
Leak in condo bathroom abefroman Plumbing 3 07-28-2010 10:59 AM
Bathroom sink supply line leak afarr Plumbing 6 05-26-2010 06:59 PM
