Internal Copper Pipe Cleaning - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-22-2011, 01:24 AM   #1
Internal copper pipe cleaning
I have just replaced a section of my copper water pipe due to a leak, when taking the section out I have noticed that there is alot of internal corrosion due to the amount of green copper oxide I can see inside the pipe. Is there any product or way of purging my complete line thought out my house to remove this build up and prevent further leaks.
handyless man is offline   Reply With Quote
Old 06-22-2011, 05:59 AM   #2
DIY staff
Rewards Points: 7,174
You must have some bad water---Sulfur? Cleaning the pipes will hasten the failure of the pipes.
If PEX is allowed in your area I suggest that you start changing the copper to a noncorrosive pipe.
----Mike---
Old 06-22-2011, 06:52 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
That green oxidation is protecting the rest of the pipe. Unless you have chunks of corrosion causing you problems, leave it. If you clean it off, it will just reform on the newly exposed surface inside the pipe. Have the PH of your water tested if you think it's contributing to any pipe failures.
Heat safety during copper pipe soldering? darsunt Plumbing 9 08-13-2011 11:48 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-27-2010 11:42 PM
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 05:29 PM
12/2 wire in contact with Hot water pipe (copper) - Dangerous? Tryvidy Electrical 6 04-21-2009 07:35 PM
misfits b/ween copper supply pipe and fittings amakarevic Plumbing 8 06-10-2008 08:39 PM
