Intermittent Toilet Mystery Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2013, 12:27 PM   #1
I have a second floor toilet that leaks occasionally from around the drain pipe area. No water ever appears on the bathroom floor. Below the toilet we have cut a hole in the kitchen ceiling and can see the subfloor, drain pipe and trap. The leak appears to be around the drain and makes the plywood subfloor wet where the drain pipe comes through. I've never actually seen it leak, just the result of it.
The leak is so intermittent that the sheetrock and subfloor have time to completely dry out between leaks even though this bathroom gets used every day. Several times I have tested running each of these bathroom fixtures by themselves and at the same time and I'm not able to make it leak when I want it to. We poured water on the floor to see if there was a crack in the tile or grout but that didn't cause it to leak.
In the bathroom there are 2 sinks, a toilet and a tub/shower. There are no A/C drain lines near by. There is a window close by but it doesn't appear to be connected to rainfall. The drain pipe is pvc.
We had a plumber come out and he wasn't sure where the leak was coming from so, he suggested we replace the wax ring to try to fix it.
Does anyone know what would cause the leak to be so intermittent and how to reproduce it?
bills_diy is offline   Reply With Quote
Old 11-18-2013, 12:32 PM   #2
Rewards Points: 44
A pic of the drain might help.
If I had to guess, I would start with the wax ring. Could be a crack in the pipe, toilet flange or the toilet itself.
You could try filling a 5 gallon bucket with water and dump it into the toilet. Pour it quickly but don't overflow the bowl. The large volume of water might make the leak show up.
Dan
djlandkpl is online now   Reply With Quote
Old 11-18-2013, 03:42 PM   #3
Rewards Points: 14,312
Unsure why you would not have changed the $2.00 wax ring first instead of letting the moisture do more damage.
A simple DIY 101 job.
jmon (11-18-2013)
Old 11-18-2013, 06:13 PM   #4
Rewards Points: 2,108
Does your toilet form condensation when one uses the tub or shower?
Tags
intermittent leak , leak , toilet , wax ring
Fixed water leak not drying under tile floor around toilet WinstonWolf Plumbing 1 05-19-2013 04:40 PM
Toilet Leak Tdsgraffiti Plumbing 5 03-17-2013 10:47 AM
leak in toilet tank and water suply Ramcatt Plumbing 3 09-03-2010 09:16 AM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
