Intermittent / Sporadic Hot Water Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2012, 06:08 PM   #1
Intermittent / Sporadic hot water issue
I was hoping someone could help me figure out a problem I've been having with intermittent hot water at my house. I've searched on the internet but have been unable to find an answer.
It seems to happen a few times a week where only lukewarm water will come out of any faucet in the house. It can happen anytime of the day, at any faucet, doesn't seem to be any pattern to it. Even though the hot water tank is full of hot water, no matter how long I leave a faucet running it remains lukewarm.
The only way I can get it to run hot like normal again, is if I go and turn on another faucet at the sametime, then after a few seconds both faucets will have hot water flowing at a normal temperature. After I do this the problem goes away and the faucet runs like normal. There doesn't seem to be any consistency to the problem. Sometimes it happens a couple times a day, sometimes once a week. The only thing I know forsure is that there is plenty of hot water in the tank.
Also, the water pressure stays the same and does not seem to change as the temperature changes from lukewarm to hot again.
Could this be a problem with the gas hot water tank, if so what part? Could it be a problem with the Thermostatic Mixing Valve for the hot water tank?
Any help is greatly appreciated! Thank you!
tbone9 is offline   Reply With Quote
Old 11-04-2012, 07:09 PM   #2
Sound like you need new elements in your water heater...it is not complicated and can be done diy
zosoplumb is offline   Reply With Quote
Old 11-04-2012, 07:18 PM   #3
I'm not sure it'd be the element just because there is plenty of hot water in the tank. It just comes out lukewarm, until I turn on a 2nd faucet at the same time, then hot water flows out both faucets like normal.
Old 11-04-2012, 08:04 PM   #4
Rewards Points: 13,732
Mixing valve would be the first thing I would be looking at.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jaydevries (11-04-2012), tbone9 (11-05-2012)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
First time home owner furnace/hot water issue rjohnson84 Plumbing 17 12-20-2010 10:40 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
