Old 05-09-2009, 08:48 PM   #1
Kap
Mowing my life away.
Default Intermittent leak
My shower.
it has a single valve-lift up to turn on, twist left or right to regulate water temp.
It will be fine most of the time, but at random times, it will start dripping. Most randomly in the wee hours of the morning.
Sometimes it just: drip............drip.................drip......... ......drip.........
other times it's drip..drip..drip..drip..
And there are times when it's just shy of being a steady stream.
When this happens, it only seems to last an hour or so.
Any ideas?
Kap is offline   Reply With Quote
Old 05-09-2009, 11:02 PM   #2
Originally Posted by Kap View Post
My shower.
Any ideas?
Could be just excess water between the valve and shower head held b/c of the surface tension of water.
handy man88 is offline   Reply With Quote
More On This Topic
Hi! This John on behalf of Expert Village. In this video clip I will show you how to fix a leaky shutoff valve. Another common problem in households is that the shutoff valves will drip over time. There is packing inside of them that will become loose... Read More »
Hi! I'm Susan Ting and I am a potter. Welcome to Expert Village and this time I will show you how to make a mask. Now this piece is ready for it to dry up and it will take probably a half a day or it could be 2 to 3 hours depending on the temp of the... Read More »
Hi! I am Melanie McLeroy with Taurus Training for Expert Village and today we are going to talk about training dogs. So here we are with Cody who has an issue with obeying her owner when she gives commands right away. She often needs several repetitions... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 9 of our process for installing a ball valve. The next thing that we want to do is go ahead and open up our ball valve so that water will flow through our pipes. Again... Read More »
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 08:06 PM
mysterious water leak Stanzaw Plumbing 11 02-13-2009 11:57 AM
Water Leak Detection AppleMac*Fit Plumbing 16 12-29-2008 08:30 AM
Leak in incoming supply line under slab playstationdork Plumbing 13 08-05-2008 10:18 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 03:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
