-   -   Insulating pipes with foam insulation (http://www.diychatroom.com/f7/insulating-pipes-foam-insulation-126018/)
thinksincode 12-08-2011 04:06 PM
Hi plumbing experts,
I picked up some Frost King PE foam pipe insulation for the basement. I have a few questions.
First, the hot water coming from the water heater. How close can I get to the heater without a flammability hazard with the water heater's flue? I think I recall something like six inches, is that right?
As for the other, cold water pipes - should I be insulating those too? The supply pipe coming in from the floor, the cold water pipe going into the water heater, ..., ? Will the PE foam insulation help at all to prevent freezing, or should I only put it on the hot water pipe(s)?
Thanks! :thumbup:
plumbing 12-08-2011 04:12 PM
Hi, are these copper? or are they pex/zurn "Plastic pipe" ?
plumbing 12-08-2011 04:23 PM
Also the stub-outs on the water heater require a special insulation it's blackish grey "with that insulation you can go right to the tank!". also i would give spray foam 8 inches just to be safe. but i usually only spray foam around hose bib and where pipe goes through Joyce/stud and yes it would prevent it from freezing, but also you should always disconnect your hose during winter to prevent freezing. I would only insulate hot/cold where pipe is near hose bib or near wall for freezing purposes. then i would only insulate HOT only when cold is a good couple feet away from slab/wall.
thinksincode 12-08-2011 04:35 PM
1 Attachment(s)
Hi plumbing,
Sorry I forgot the pipe type. They are copper.
I disconnected my hoses and turned off the valves for the pipes going outside, I was just wondering if adding the foam insulation on the cold pipes would help prevent freezing or if I should only bother with the hot water.
Also it's not spray foam, but pre-slit PE foam that you place around the pipes then seal with tape (I attached a picture of what I'm using).
plumbing 12-08-2011 04:49 PM
Sorry i am getting confused with other posts, and that's the stuff! it will help keep your Hot water hot longer when not used for a while and cold water from getting frozen so i would insulate from main to the heater then to hose bibs and hot from the heater then i would do the hot the rest
mnp13 12-08-2011 05:03 PM
Putting it on the cold pipes will also help with condensation in the summer
thinksincode 12-08-2011 05:06 PM
Great, thanks guys!
