-   -   Insulating Hot Water Lines (http://www.diychatroom.com/f7/insulating-hot-water-lines-4935/)
jeepwillies 11-21-2006 09:25 AM
I am in the middle of a home reno, and before I put up the dry wall i was thinking of wrapping insulation around my hot water lines. My thought is that I will not have to run the hot water as long before I actually get hot water at the tap. This is all just to conserve water (environmentalist in the making!).
Does anyone think this would help?
majakdragon 11-21-2006 02:41 PM
I don't believe the cost would offset any savings you MAY get. Insulation does not "heat" the water, so after a while of setting, the water would cool off anyways. If you want cost and water savings, install a circulating pump so that the hot water is always in the lines. OR, better yet, install a pump with a convienient switch so that when you need hot water, you can hit the switch and have instant hot water without wasting water.
