To Insulate Or Not - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2009, 09:56 PM   #1
to insulate or not
finishing my basement and will be dry walling ceiling .....do I insulate water pipes ? they are cold water pipes... thanks
44070dart is offline   Reply With Quote
Old 11-27-2009, 10:00 PM   #2
Registered User
Termite's Avatar
The question is too general. I presume we're talking about copper pipes? If your water pipes are installed on exterior walls (bad idea) then you should insulate the wall on the cold side of the pipes. If they're in cantilevered joist spaces, insulate. If they're in other parts of the basement and the basement and the house above is properly heated there is no need to insulate your pipes to protect them from freezing.
Old 11-27-2009, 10:25 PM   #3
sorry.. they are copper .. in the joist .. will be enclosed in dry wall ceiling worried about condensation ..thanks will insulate
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
How to insulate attic crawl space RISurfer Building & Construction 7 10-01-2009 11:57 AM
Insulate Cellar? newbieowner Green Home Improvement 3 04-26-2009 09:18 AM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 06:07 PM
How to insulate under a shed floor 6n165 Building & Construction 3 01-04-2008 11:55 AM
