Insualtion Around Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2013, 11:16 AM   #1
Insualtion around vent Pipe
I have just moved my laundry up to the 2nd floor in my home. The plumber installed an in wall vent for the drain. It's on branch off my drain that goes up a few more feet and has one of those special PVC fittings.
I would like to insulate with fire/sound insulation. Can this be done around the vent or will hinder the air flow and slow my drain?
Thanks,
Cb
cenergy is offline   Reply With Quote
Old 03-29-2013, 11:58 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Insulating around the outside of a vent pipe would not have any affect on its venting abilities.
fetzer85 is offline   Reply With Quote
Old 03-29-2013, 12:37 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 674
Thanks,
Cb
If he installed an AAV- it needs to breath air from the room. Insulate the pipe only
Old 03-29-2013, 01:33 PM   #4
It is an AAV, and is in a stud bay. It's about at the 6 foot mark in a 7 1/2 bay. Is 1 1/2 feet of air enought breathing room if I insulate all the way up to the vent?
Old 03-29-2013, 02:15 PM   #5
Plumber
Rewards Points: 674
It needs air from the room. So if you sheetrock the wall leave an opening and put a simple fresh air grill/louver on it. Keep the insulation clear of the AAV
Old 03-29-2013, 03:26 PM   #6
Rewards Points: 13,712
Why do you feel the need to insulated a vent line? There's nothing in it but gas, it's not going to freeze.
That vent also needs to remain accessible, it can not be behind a wall.
Old 03-29-2013, 04:08 PM   #7
I am insulating the room behind the wall. its a bedroom.
Old 03-29-2013, 08:37 PM   #8
Rewards Points: 1,950
That AAV must be accessible does he have a grill or something so you can replace it once it fails and starts stinking?
Old 03-29-2013, 09:53 PM   #9
Roofmaster
Rewards Points: 2,210
Just install a simple return air grill right where the AAV is. That gives you accessability, and free air. Put the louvers up
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
using section of pipe for both drain and vent amakarevic Plumbing 6 05-11-2011 12:20 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Hot Water Heater Improper Vent Pipe Danger fritzycat1 Plumbing 2 07-27-2009 10:34 AM
stuck iron pipe on oil tank vent wrybosome Plumbing 3 01-13-2009 09:43 PM
