Instead Of Cooper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2009, 12:53 PM   #1
Instead of cooper pipe
I need to replace a 15' section of 2" cooper pipe that is in a concrete floor,I'd rather not have to dig up the floor so I'm running the pipe over head. what can I use instead of cooper,it's for hot water that feed a bank of washers
kart7ny is offline   Reply With Quote
Old 11-04-2009, 01:57 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
As far as I know, PVC is the only alternative to copper for water, and only in certain instances - never indoors and only for COLD water.
hyunelan2 is offline   Reply With Quote
Old 11-04-2009, 02:02 PM   #3
www.pexsupply.com/ I found this stuff check it out.
Kurt1968 is offline   Reply With Quote
Old 11-04-2009, 09:56 PM   #4
Irrigation Contractor
Location: South Central British Columbia - The great White North
Originally Posted by kart7ny View Post
I need to replace a 15' section of 2" copper pipe that is in a concrete floor,I'd rather not have to dig up the floor so I'm running the pipe over head. what can I use instead of cooper,it's for hot water that feed a bank of washers
I don't think that you have much of a choice. In some areas you can have PVC indoors, but only sch40. But again, only for cold water. PEX can come in 2", but it can be hard to get fittings and tools. I would check with your local plumbing inspector to see what would be an acceptable alternative to copper. I would go with copper myself. It will be the best choice in the long run.
Water Guy is offline   Reply With Quote
Old 11-04-2009, 11:27 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Use CPVC. PEX is great, but as said before, getting the proper tools to install PEX can be a bit of a problem. This is especially true if you only need to do a one time install. Unlike PVC (polyvinyl chloride), CPVC (Chlorinated polyvinyl chloride) is suitable for both hot and cold domestic water and can be used indoors. In addition it is relatively easy to install. Be sure you have the piping supported every 4' for your horizontal run. Any good plumbing supply house will have everything you need.
Good luck
JDC is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
