Installing A Whole House Water Filter - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2017, 01:03 PM   #1
Rewards Points: 6
Installing a Whole House water filter
I want to install a Whole House Water Filter I bought for my DR Horton house built back in 2007 (the builder says the don't have the drawings available anymore). The house is not pre-plumbed for a water softener so I cannot figure out where the main water line comes up out of the slab. I have my water heater located in a closet in the Laundry room on the first floor of the two story house. Does anyone know where the pex manifold/ main water line would be located? I already checked inside the wall right next to where the main water line enters the slab since I saw some house had their softer there but I now think they just cut into the main on the outside of the house and piped it into the house and then back out of the house. All I can think of is that it is behind the water heater or maybe behind the washer/dryer units. Thank you for any help.
tallfixer is offline   Reply With Quote
Old 01-09-2017, 01:10 PM   #2
Rewards Points: 378
Re: Installing a Whole House water filter
Can you find the meter?
stick\shift is online now   Reply With Quote
Old 01-09-2017, 03:52 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 444
I'm confused.
Also, do you wish to install a water filter or a water softener?
lenaitch is offline   Reply With Quote
Old 01-09-2017, 04:35 PM   #4
Rewards Points: 6
Stick/Shift- I know where the meter is and where the water main enters the house foundation. I don't know where the pipe would come out of the foundation that would split off to everywhere else in the house (the Pex manifold). I would think it would be installed on a none insulated interior wall rather than an insulated exterior wall. All walls are 2x4 construction.
Lenaitch - I am installing a whole house water filter only. I used the water softer as an example since it is usually an option to have building install connections for the softener more often than a whole house water filter.
Old 01-09-2017, 04:41 PM   #5
Rewards Points: 378
So the meter is outside the house?
Old 01-09-2017, 04:43 PM   #6
Rewards Points: 6
yes, by the street and sidewalk.
Old 01-09-2017, 05:06 PM   #7
Rewards Points: 378
So much for that idea - around here they're inside the house....
Old 01-09-2017, 05:25 PM   #8
Usually Confused
lenaitch's Avatar
Rewards Points: 444
That's intriguing. I would think if you knew the entry point on the outside then the emerging point on the inside would be the same spot. I can't imagine a situation where a water main would not simply pass straight through the foundation.
Need help with whole house filter for well water CreepyOldGuy Plumbing 0 07-10-2016 10:58 AM
Water softener and whole house filter Verbalkint99 Plumbing 1 08-06-2015 11:58 AM
Whole house water filter mj12 General DIY Discussions 11 01-23-2015 11:59 AM
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
