Installing Water Softener: Reducing Pipe Size. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 01:00 PM   #1
Question
Installing water softener: reducing pipe size.
Hi,
I want to install a water softener but the main inlet pipe size is 1 1/4" and the softener is 1". Can the main pipe be reduced to 1"? I have 3 bathrooms and 7 people in my house. Thanks
handyman92865 is offline   Reply With Quote
Old 01-18-2013, 01:15 PM   #2
Rewards Points: 13,694
Sure can be. Most homes only use 3/4 for the main runs so 1" would be even better.
What kind of pipe is it?
Old 01-18-2013, 01:20 PM   #3
It's a copper pipe. I bought a unit from sears and had a plumber came over to install it. He said it cannot be installed because of the differemt in pipe size. He said he cannot reduce the pipe from 1 1/4 to 1" because the water pressure will reduce greatly. Please advise. Thanks.
Old 01-18-2013, 01:28 PM   #4
Total BS. Inless this is a multi unit apartment building it would work fine.
Let me guess he wanted to sell you a softner with a bigger, hole?
DidIDoThat (01-24-2013)
Old 01-18-2013, 03:19 PM   #5
Yeah he said I need to get a softener with a bigger hole.
Old 01-18-2013, 03:38 PM   #6
And he want to pick up up for you and then mark it up.
That's where they make more money.
Time for a new plumber or do it yourself.
Old 01-18-2013, 04:55 PM   #7
Yeah, Sears already charged me $159 for installation and this guy was charging me another $260. I asked why does he has to charge $260 extra? He said what I paid was the "Sears installtion". I'm really confused so I told him I'll just do it myself.
Old 01-19-2013, 10:19 AM   #8
Code in many areas requires that the inlet size of the softener match the pipe size coming in so the plumber may have been advising you of what is required to satify code.
Bob999 is offline   Reply With Quote
Old 01-19-2013, 08:22 PM   #9
Do you think it is safe to reduce the pipe size from 1 1/4 to 1" though?
Old 01-19-2013, 08:30 PM   #10
Why not contact the water softner company?
Old 01-20-2013, 12:03 AM   #11
747
registered
747's Avatar
Rewards Points: 534
Cut pipe and sweat this in. Problem solved.
http://www.homedepot.com/Plumbing-Pi...1#.UPuIn2eHgQ4
747 is offline   Reply With Quote
Old 01-20-2013, 12:28 AM   #12
I've never even seen any home with a 1-1/4 supply line, sounds odd ball to me.
Old 01-20-2013, 01:15 AM   #13
Rewards Points: 6,652
Only place that I can think of that would use a incoming line size like that, would be a commercial structure. I am calling bunk on this one also. At around 23gpm, that is a lot of water gushing into that softener system.
Old 01-20-2013, 02:13 AM   #14
Thanks!
Old 01-20-2013, 10:03 AM   #15
Not a safety issue so far as I can see. As others have posted it is difficult to imagine that a 1" line is not sufficient for a typical home.
But that said codes are developed for what are typically good reasons and failure to follow code can cause problems down stream when, for example, trying to sell a property.
Installing a Water Softener amorak Plumbing 3 05-04-2012 10:56 PM
Water Softener Questions :) Einzee Plumbing 6 08-13-2011 11:55 PM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-19-2009 11:53 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
