Installing A Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2012, 12:02 PM   #1
Installing a Water Softener
Hello everyone,
I just purchased a used Rainsoft EC4 water softener. The unique thing about it is that it has a second resin tank. If I read the user manual it doesn't mention anything about a second tank. All it shows is a single resin tank with the controller head on it and standard salt bin.
Would anyone know how to plumb in a second resin tank? In serial or parallel? Other?
I think it is a back up to ensure a high capacity of soft water at all times.
Thanks,
David
dmwisniewski is offline   Reply With Quote
Old 03-10-2012, 12:40 PM   #2
Water Treatment
Rewards Points: 848
Originally Posted by dmwisniewski View Post
Hello everyone,
Thanks,
David
Second Salt tank?
Why would you wish to have a second salt tank?
Plan on using more than 300lbs per month?
Akpsdvan is offline   Reply With Quote
Old 03-10-2012, 01:19 PM   #3
Originally Posted by Akpsdvan View Post
Second Salt tank?
You must have missed what I said, it is a second resin tank, not a second salt bin. The system I have is as follows:
1) salt bin for holding salt
2) First resin tank with controller
3) Second resin tank, no controller
I would like to know to best way to connect the system.
Thanks,
David
Old 03-10-2012, 02:12 PM   #4
The units that use twin media tanks that I am familiar with have a control head that is designed to connect to both tanks and automatically switch between them. Fleck makes several twin tank control heads--9000, 9100 being the most common used in residential settings. The TwinFlo is also a twin tank control head.
Here is a link to literature on the Fleck control heads--perhaps the unit you have is a variant of a Fleck control.
http://www.pentairwatertreatment.com...ControlValves/
Bob999 is offline   Reply With Quote
Old 03-10-2012, 03:01 PM   #5
Water Treatment
Rewards Points: 848
My bad, shows that I should have coffee before coming to the forums and posting answers.
If you have a photo it would be cool, but as Bob has given a link there should be a page that shows what you most likely have and how it goes together.
Old 03-10-2012, 11:04 PM   #6
Has he said how the two tanks are connected? Would it be an upflow filter, maybe carbon or calcite?
Andy CWS is offline   Reply With Quote
Old 03-11-2012, 03:30 AM   #7
Water Treatment
Rewards Points: 848
Think that it is the Rainsoft version of the Fleck 9100... and if that is the case they go together like the 9000 ..
There is a yoke that goes from main valve to the second tank adapter.
Easy Peasy...
Low water Pressure with water softener garden Plumbing 8 07-31-2012 02:03 AM
Water Softener Drainage Problem hodge23 Plumbing 3 09-26-2011 05:40 PM
Culligan water softener not working (pics) Perm Plumbing 46 09-14-2011 01:29 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
