Installing Water Heater Water Catch Dilemma - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2009, 01:04 PM   #1
Installing water heater water catch dilemma
My housing inspector said the water heater to a condo I bought is old, but works fine. He said I should place a leak catch under it though in case it broke so I wouldn't damage my unit, or the unit below.
However, I'm unclear on how to get the tub underneath it. In the picture you can see the heater, and the black tub with a lip next to it. I can't lift the heater though, at least I don't think I can without cracking the stiff metal tubing that runs from the top.
Does anyone know of a product or makeshift approach to me getting some kind of water catch under there? Thx.
bbooze is offline   Reply With Quote
Old 12-05-2009, 01:10 PM   #2
The tubing on top is flex tubing
Myself I wouldn't touch it
I'd only put a pan in when replacing the WH
They are heavy & bulky
If you want to Drain it, get 3 people to help you lift it just enough to slide the pan under
Ideally you want the WH up off the pan
So that small amounts of water that may leak into the pan will not rust the bottom of the tank out
Old 12-05-2009, 02:11 PM   #3
Remodeling Contractor
drain the unit. (turn off the electric first). Then place the pan under it. The lines above will flex enough for this process.
Old 12-05-2009, 02:35 PM   #4
Registered User
Rewards Points: 4,892
If you put a pan under it, be sure to run a drain pipe outside for the water to go rather than fill the pan and over-flow.
Check with the Condo rules, two straps may be required in case of earthquake/overturn, as they are in townhouses... IRC {2801.7} On page #6 here: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Also add longer flex lines to create heat loops, in the picture above the tank so you are not constantly heating the supply and exiting water pipes.
Notice in the code, your TPRV should be piped outside, not to the floor.
Did your inspector check for a lockable breaker to the unit since there is no switch near the unit? This would be good to know the location if every a problem and a remote switch is somewhere near the panel if not a lockable breaker.
Be safe, Gary
Gary in WA is online now   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
"sticky" gas water heater thermostat homer12 HVAC 7 01-22-2008 07:08 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
