Old 09-11-2008, 06:16 PM   #1
Monika2024's Avatar
Installing a washer/dryer from 2nd story to basement....
Hi..OK so here's the issue I'm facing, we bought a newer home which has a washer/dryer on the 2nd story. Yup, I want to move it into the basement-I know I'm crazy. I'm the kind of person that does laundry last minute...so having it upstairs is noisy, shaky, etc etc...and I just don't like it up there (plus I enjoy caring it up three flights of stairs from the basement - think workout!) Anyway, we have township sewers and the pipes are about 7 feet from the basement floor which eventually flow into the main drain (I think --the fat pipe-for the lack of better explanation) thats about 3 1/2 feet from the floor. The kitchen sink pipes are above the area I want the washer to be. I was advised that I needed to a) install a pump that connects to the kitchen drain pipes, or b) install pipes half way up the wall that slightly lower (to allow for gravity to do its work) into the main drain thingie (the fat pipe). Anyway here are some pics..one of my new GE red washer and dryer with the water connection to the left and the kitchen sink pipes above the dryer to the right...the second pic is of the the pipes under the sink. So what is my best option here? Any help is greatly appreciated..Just not keeping it up on the 2nd story.
Installing a washer/dryer from 2nd story to basement....-basement-2.jpg   Installing a washer/dryer from 2nd story to basement....-basement-1.jpg
Monika2024 is offline   Reply With Quote
Old 09-11-2008, 06:19 PM   #2
Monika2024's Avatar
Also, I am assuming that if I wanted to install a utility sink, I would def. need a pump, correct?
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 12:11 PM
Installing walk up basement allworld Building & Construction 6 11-22-2007 12:59 AM
Installing Registers in finished basement boinger HVAC 2 02-07-2007 04:44 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
