Installing Vessel Sink Drain?! (HELP!) - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2006, 09:29 PM   #1
installing vessel sink drain?! (HELP!)
We're installing a vessel sink in our bathroom - so far we've successfully connected the faucet (no leaks!). However, we can't figure out the drain. It's an American Standard white vessel sink with an overflow. There are holes cut in the drain (for the overflow, obviously) - however, the sink came without instructions.
We've got a rubber washer/seal, a hard plastic ring, a drain with a long metal pipe, and a metal nut that holds it all together. We're puzzled. Where does the rubber seal go? Does it rest inside of the sink (between the two layers of porcelain?) or does it go underneath the countertop?
If anyone's installed these sinks (it's the three-in-one vessel sink from Home Depot), please send your advice our way.
Thanks!
tara is offline   Reply With Quote
Old 11-09-2006, 11:40 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Rubber washer should go on botton side of sink.
Ron The Plumber is offline   Reply With Quote
Old 11-10-2006, 01:17 AM   #3
747
registered
747's Avatar
Rewards Points: 534
Listen you should use plumbers putty on the top of the sink. Roll it out in your hand like a snake then run it around top of the metal pipe before sitting into sink. When you tightened it down from underneath it will start to uzz out thats ok it is suppose to.
747 is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
Drain for an "Outdoor Kitchen" Sink Rich Plumbing 5 08-26-2006 07:48 AM
