#1 |
Installing Utility Tub w/ Pump into Horizontal Drain
I’d need to install the utility tub as per the photograph, or alternatively tie the washer in to the left of the dryer (where there is a clean, horizontal run) and place the utility tub where the washer is. The only item that can’t be moved is the dryer. As you can see, I’ve got the utility sink and the pump. The downpipe far left is waste, the middle is vent (I believe), and the right is waste.
I’d like to avoid tying the pump into the drain where the washer drains, and have the washer drain into the tub. Thanks so much for your help. |
| Display Modes | |
| Horizontal Washer Drain AFTER Standpipe 3 inch?????? | hammerlane | Plumbing | 23 | 11-01-2011 10:06 PM |
| utility pump problem | pumprob | Plumbing | 5 | 02-23-2010 12:03 PM |
| Advice re: installing utility sink in basement | Pickngrin | Plumbing | 2 | 12-20-2009 03:15 PM |
| Installing basement shower drain | atilla137 | Plumbing | 5 | 09-03-2009 12:54 PM |
| utility sink pump? | mepeterser2451 | Plumbing | 3 | 12-01-2008 11:46 AM |
