-   -   Installing Utility Tub w/ Pump into Horizontal Drain (http://www.diychatroom.com/f7/installing-utility-tub-w-pump-into-horizontal-drain-170421/)
SkiierGuy 01-28-2013 07:21 PM
1 Attachment(s)
Iíd need to install the utility tub as per the photograph, or alternatively tie the washer in to the left of the dryer (where there is a clean, horizontal run) and place the utility tub where the washer is. The only item that canít be moved is the dryer. As you can see, Iíve got the utility sink and the pump. The downpipe far left is waste, the middle is vent (I believe), and the right is waste.
Iíd like to avoid tying the pump into the drain where the washer drains, and have the washer drain into the tub.
Thanks so much for your help.
